Issues with 2003 XJR?
Old May 5, 2009 | 03:23 AM
Fairlane500's Avatar
Default Issues with 2003 XJR?
I'm looking for a 2003 XJR (as I prefer the styling before the aluminum body). Are there any particular weaknesses that I should be on the watch for? How about an upper limit on mileage?
Any input would be appreciated - Thanks
JF
Old May 27, 2009 | 12:37 PM
Racerwrx66's Avatar
No love for this thread? I'm looking at 2000-2003 XJR's, and I'd also be interested in the answers to these questions. If not, can any of you point me in the direction of a good resource?
Old May 27, 2009 | 02:04 PM
hrand1987's Avatar
I have had my 2003 xjr for about 6 months and no major issues, it has about 55000 miles on it. Like anything else try to get a clean car with good records. Try to stick with 02 03 01 have a tendency of having milky wood (can be restored for about 2k keep in mind your wood would be out of car for a few months) and certain 2000 andevery 98/99 have timing chain tensioner issues. 98 have nikasil issues but i believe many engines were replaced under warranty. BTW when you do get one becareful, the gas pedal is shall we say sensitive
Old May 27, 2009 | 05:20 PM
jag_genius's Avatar
not much problems.. slight trani leaks from connector orings.. ball joints.. brakes.. nothing major tho .. only little things..
Old May 28, 2009 | 08:04 PM
Racerwrx66's Avatar
thanks for the info! so, '01-03 XJR's might be a better choice to be looking at, with around 70-90K on the clock, compared to '03-05 S-Type R's with similar mileage? (i'm basing this on reading that STR's seem to fall apart at 100K.)
Old May 30, 2009 | 12:19 AM
andnew's Avatar
I'm at 81K and I'm starting to feel the front end getting loose. I'll be taking it to the dealer in a couple of months just because I don't currently have a lift or alignment rack. :-)
I have seen and fixed the trans o ring failure mentioned, a new set of wiper relays, and done nothing else but tires, brakes and service.
This has been the single most trouble free car I've ever owned. 03 XJR W/R1 package.
Old May 31, 2009 | 08:54 AM
jag_genius's Avatar
stype R can be more expensive to maintane .. with the ZF trani and aluminum suspension..
Old Jun 2, 2009 | 04:59 PM
Racerwrx66's Avatar
ok, thanks guys!
Forcedair1
Sep 8, 2025 01:57 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
XJsc-guy
Sep 25, 2015 11:09 AM
OkieTim
Sep 2, 2015 12:48 PM
