Knock sensor P0332, P0327 and battery not charging
Old May 19, 2024 | 03:41 PM
BrknJag's Avatar
Exclamation Knock sensor P0332, P0327 and battery not charging
Hello Everyone, This is my first time here and I’m hoping to get some help on my issue before I go to the mechanic.
I drive a 2001 Jaguar XJR X308 that I’ve had for 5 years now. I was cleaning my engine bay with water ( making sure I don’t hose directly into connecters). I removed my air filter and intake ( I made sure to cover the throttle body).
Once I was finished and put the car back together, I started the car and got Restricted performance and knock sensor code P0332 and P0327. I thought it was a fluke given I never had that issue before. I decided to clear the code and disconnect the battery and connect it again hoping it would go away…Not only did the codes come back but now I have a “Battery not charging” light on the dash as-well. I left the negative cable unplugged for the night and now this morning I tried and all the lights are still there. I started to think maybe when I was cleaning, the water went somewhere it shouldn’t be. Not sure what to do now unfortunately… I’ll take any help I can get. Thanks!
Old May 19, 2024 | 06:31 PM
Addicted2boost's Avatar
Unplug both knock sensors, spray WD40 (Water Displacer) inside connectors and let it air out a few minutes before plugging back in. The alternator might be a different story but, focus on one thing at a time. Hook battery back up and clear the codes prior to starting. See if at least the knock sensor codes went away before proceeding.
Old May 19, 2024 | 06:46 PM
BrknJag's Avatar
Thanks for the reply! However, to reach knock sensors, Do I have to remove the supercharger? If so, without a clear cut step by step video on how to do it, I'm not sure I feel confident enough to do it by myself without instructions..
Old May 19, 2024 | 07:57 PM
No, the connectors are located on a metal bracket just in front of both intercoolers. Where the cooling hoses go into and out of the intercoolers. Both connectors are right next to larger oval connectors. They’re 2 wires in each one that you’re looking for.
Old May 19, 2024 | 08:25 PM
BrknJag's Avatar
Alright thanks!
What should I do next once I do that? Just the car again hoping the code went away?
Best,
Old May 20, 2024 | 12:35 PM
BrknJag's Avatar
Just to make sure, is this the right connector? Thanks
Old May 20, 2024 | 04:24 PM
Silverjag0's Avatar
Say goodbye to the alternator
Old May 20, 2024 | 05:17 PM
No, that’s a fuel injector connector.
Passenger side. Attached to a metal bracket.
Drivers side. The left connector. You might as well check both of them on each side. The oval connector is for the fuel injectors.
Old May 20, 2024 | 09:04 PM
BrknJag's Avatar
Thank you for clarifying!
I'll keep you updated once I got it done and let you know the results!
Best,
Z07Brandon
Nov 24, 2018 05:38 PM
King Charles
Jun 23, 2017 09:57 AM
jagastruckerhoodornament
Apr 11, 2014 12:45 PM
phaelax
Feb 8, 2014 07:49 PM
Sparkers69
May 15, 2009 07:22 PM
