Location of EMS bulkhead ground stud
Old Feb 14, 2016 | 02:22 PM
xjr2014_de's Avatar
Default Location of EMS bulkhead ground stud
Hi to all,
Since the preowner of my car retrofitted the heated windscreen but didn't install the windscreen heater harness, I did that today. I found the harness connector hidden behind the throttle body, but I couldn't find the ground stud.
The electrical guide says, that the harness should be connected to the "EMS BULKHEAD GROUND STUD". Can anybody tell me, where I can find its location or mark it on my pictures? Or do you have other ideas, where to connect the eyelet instead?
And do you know, where the relays are attached to?
Thank you very much!
Best regards, Alexander
Attached Thumbnails Location of EMS bulkhead ground stud-windscreen_harness-1.jpg   Location of EMS bulkhead ground stud-windscreen_harness-2.jpg   Location of EMS bulkhead ground stud-windscreen_harness-3.jpg
Old Feb 14, 2016 | 05:06 PM
avern1's Avatar
I have attached a sheet showing the XJ8 ground points. The EMS is in the center of the engine compartment bulkhead. It is not necessarily a stud. Look for a fastener bolted to the bulkhead with wires on it.
File Type: doc
Old Feb 15, 2016 | 02:30 AM
xjr2014_de's Avatar
Hi avern1,
thanks very much for your info. I found that particular figure in the electrical guide as well, but I didn't manage to locate the ground stud anyway since it's very cramped behind the throttle body.
Other ideas? Maybe it's hidden behind the wiper motor assembly?
Cheers, Alexander
Old Feb 16, 2016 | 12:20 PM
xjr2014_de's Avatar
GOT IT!
I had to remove the purge valve in the engine compartment (see figure 3). Below this the ground stud is located (figure 1). To attach the relays of the heated windscreen harness you'll find a retaining plate on top of the transmission bell housing (figure 2).
Cheers, Alexander
Attached Thumbnails Location of EMS bulkhead ground stud-ems_bulkhead_ground_stud_1.jpg   Location of EMS bulkhead ground stud-ems_bulkhead_ground_stud_2.jpg   Location of EMS bulkhead ground stud-ems_bulkhead_ground_stud_3.jpg
rocklandjag
Oct 10, 2018 01:41 AM
adenshillito
Apr 17, 2016 02:49 AM
gozoom
Feb 15, 2016 10:11 PM
carl langley
Feb 15, 2016 06:21 AM
StealthPilot
Feb 14, 2016 08:20 PM
