Loose sunroof
Old Dec 20, 2011 | 08:05 PM
obriendob's Avatar
Default Loose sunroof
Hi
Seems I need help with my 98 XJ8 sunroof
It opens and closes. It does not leak.
But it is loose. When you close the door, from outside, you can see the sunroof move. When you are in the car, driving a bumpy road the sunroof rattles. It is worse in cold months.
If the roof is open or tilted - no noise.
I had a local sunroof/convertible repair shop look at it. He told me the unit is old, worn and not repairable. No adjustment or part could fix this.
Has anyone had this problem?
This noise can be unnerving - ruins a great ride
Old Dec 21, 2011 | 06:34 AM
jimlombardi's Avatar
Welcome to the forum.
Look at this Sunroof sliders thread, another forum member was also having the same problem (sunroof panel rattles like crazy):
https://www.jaguarforums.com/forum/x...sliders-52248/
Also you should call Nalley Jaguar (one of the forum sponsors) and ask if Sunroof clip kit is still available and if it would fix your panel rattling issue (part# jlm21698) retail price is about $30 (mention you are forum member - 15% discount and free on orders over $25).
I found the kit part number in the Jaguar Electronic Parts Catalog. There is no other information and it is not on the Sunroof JEPC diagram.
There some other sunroof threads:
https://www.jaguarforums.com/forum/xj-x308-xj8-xjr-27/98-xj8-sliding-roof-trim-7777/
https://www.jaguarforums.com/forum/xj-x308-xj8-xjr-27/problems-2002-xj-sport-sunroof-aerial-45880/
https://www.jaguarforums.com/forum/xj-x308-xj8-xjr-27/sunroof-panel-sagging-36245/
The JTIS shop repair does not give enough information and illustrations on the sunroof problems or show how to fix the clips and what to do when the panel gets unhooked.
Hope this helps
Jim Lombardi
MrWhite
33
Oct 22, 2015 10:29 AM
JungleJonny
Oct 5, 2015 03:52 PM
10 XF Premium
Oct 2, 2015 09:22 PM
JagBrian
Oct 1, 2015 12:52 AM
millertic
Sep 30, 2015 08:11 PM
