My Ipod Dash Install
Old Apr 7, 2011 | 04:25 PM
pd_regan's Avatar
Default My Ipod Dash Install
Hi guys, thought I’d share a few pics. of my iPod install I’ve just completed into the dash of my XJ8. Im well pleased.
Bought a spare set of centre vents off ebay and went to work cutting them down to fit, I guess years of making plastic Airfix models as a kid all came rushing back . The ipod sits into a cut down dock so it wakes up when the ignition is turned on, go's back to sleep when I shut off, courtesy of some jailbreak apps. Plays through the cd line in by the usual method of tapping into an ainet extension cable, so all can be reversed back to original spec if required.
Hope you like
Pete
Attached Thumbnails My Ipod Dash Install-100_0740.jpg   My Ipod Dash Install-100_0746.jpg   My Ipod Dash Install-100_0750.jpg   My Ipod Dash Install-100_0753.jpg   My Ipod Dash Install-100_0752.jpg
Old Apr 7, 2011 | 07:50 PM
TN8Shooter's Avatar
Wow, great install. Looks like it came from the factory. Did you have to trim down the vent registers?
Old Apr 7, 2011 | 08:17 PM
TheJagster's Avatar
Top quality!
Old Apr 7, 2011 | 08:29 PM
bob5tafford's Avatar
Fantastic! You are truely an ARTIST!
Old Apr 7, 2011 | 08:37 PM
JaguarXJR02's Avatar
Very Nice!
Old Apr 8, 2011 | 01:21 AM
DavidN's Avatar
Superb !!!
Definitely the best & cleanest iPod integration on an XJ8 I've ever seen.
Did you use the rear console vents?
Is it a fixed installation or can the iPod be removed?
Any pictures of the "construction" process?
Old Apr 8, 2011 | 03:47 AM
Cadillac's Avatar
It looks like a factory option rather than aftermarket , nice job in every way
Old Apr 8, 2011 | 05:25 AM
pd_regan's Avatar
Thanks guys your comments are much appreciated,
@DavidN
Thanks Dave, Ive used part of the case that a new iPod comes in, the part the ipod clips into, I modified it with a slot one end, and fixed the internals of a cheap docking station to it, this gives me a jack output as well as the ipod cable input at right angles, so the plugs enter from the back. The unit can be unclipped from its holder but you really have to remove the trim first. So I guess its semi-fixed.
Ive attached the only pics I have of the construction, dosent show a great lot of detail but you can see the dock plug poking out of the mount, and the cutting down of the original vanes to fit the cut and shut vent opening.
Attached Thumbnails My Ipod Dash Install-100_0729.jpg   My Ipod Dash Install-100_0730.jpg
Old Apr 8, 2011 | 09:39 AM
SuperSport's Avatar
Not just an amazing job of the installation, but the technological side is fantastic too. I'm RARELY a fan of butchering the dash of a car, but you really accomplished a factory look, which is Very rare.
I too am a phone hacker, so I appreciate the time spent getting the device to compliment the interior too. Love the clock...
Old Apr 8, 2011 | 03:53 PM
QuadManiac's Avatar
Beautiful job, pd... what I can't find are the joints in the rectangular registers. I realize you had to cut them down in width but I can't see where they were glued back together after cutting... just beautiful! Where are they and what did you use to hide them - plastic model filler and a re-paint?
Old Apr 8, 2011 | 04:08 PM
Beautiful job PD, looks really professional.
Pity you didn't photograph the whole process, c'est la vie!
Old Apr 8, 2011 | 06:04 PM
pd_regan's Avatar
@Quad
Cheers buddy, I tried quite a few glues to bond that plastic together, ABS, super glue, two part glues, I think I tried all the modelling adhesives, nothing would hold it firm enough, I ended up using a soldering iron and welding the plastic back together using the cut offs to build up the joints over size then file and sanded it back until it looked ok to the eye, then a coat of flat black paint, sprayed from about 18" in short bursts to give it a bit of texture, giving away all my secrets now , you can see one of the joints, right hand vent, top edge about 20mm in from the left edge, I can can see it in the 1st construction photo, but I sorted it before fitting. (I think I got a detail problem)
@Norri
Thank you, I always seem to get too engrossed in the job im doing to remember to take pics, sorry
Old Apr 8, 2011 | 08:15 PM
dba-one's Avatar
When I saw the title of the thread I expected to see some messy dash mount perhaps held on with glue or even double sided tape. That is some first rate work you did there.
Old Apr 9, 2011 | 01:20 AM
SirJag's Avatar
Good show... quite impressive indeed!
SirJag
Old Apr 9, 2011 | 03:47 AM
Stu 1986's Avatar
That is a really nice job, you clearly took the time there. I bet you could make a bit of money making and selling those on request if you wanted! I like the clock app with the leaper and the way it doesn't harm the harmony of the interior. Well Done
Old Apr 9, 2011 | 11:21 AM
squish's Avatar
Wow! I'd even use something that looked half as good as long as it WORKED. Well done.
Old Apr 9, 2011 | 02:18 PM
pdog2000's Avatar
wow very nice...you should sell these...I'd buy one
Old Apr 9, 2011 | 02:35 PM
pezzonovante88's Avatar
Wow. You're very skilled. It's so cool too with the Jag clock app. Nice job, man!
Old Apr 9, 2011 | 05:10 PM
dba-one's Avatar
The more I look at the pictures the more I appreciate the skill and attention to detail that went in to this. The Leaper and clock just make it so much better.
Old Jul 30, 2011 | 05:06 AM
Iqon's Avatar
That's awesome.
