Mystery Part?, black plastic hose connector
Old Feb 4, 2024 | 06:29 PM
amarjr's Avatar
Default Help Identify mystery part?, looks like black plastic hose connector
Any guidance where this part needs to be reinstalled / replaced and how to complete the repair?
Vehicle: 2002 VDP, 71k miles
Found this on garage floor:
Black plastic
1' diameter x 1.5" length
Ridged exterior
One end has inner cylindrical fitting
Other end has bowled reducer
Inside opening ~ 0.5"
First pic shows as it was found on the garage floor. Where the car was parked, this was found just left of center between front axle and firewall.
I have not yet been able to look underneath the car for any additional clues.
Really appreciate the advice of this group.
Thank you
Attached Thumbnails Mystery Part?, black plastic hose connector-04f3a780-6c0b-49f9-8ab1-cab735fe46a5_4_5005_c.jpeg   Mystery Part?, black plastic hose connector-c01ac720-fa14-4f87-8021-c3d1f01ac6e5_4_5005_c.jpeg   Mystery Part?, black plastic hose connector-80d1eda0-b31d-4abb-8c61-9ed007897c5a_4_5005_c.jpeg   Mystery Part?, black plastic hose connector-4370b48b-0cb1-4cb5-b6a4-1c4f7561c772_4_5005_c.jpeg
Old Feb 4, 2024 | 07:24 PM
motorcarman's Avatar
That plastic part is placed in the bolt hole for one of the long bolts holding the front subframe to the body.
The bolt won't fall out of the 'tube' if the plug is in place and it is (the bolt) loosened/removed.
Not necessary but probably for assembly line installation.
Old Feb 4, 2024 | 07:35 PM
RJ237's Avatar
You are amazing, Bob.
Old Feb 4, 2024 | 08:00 PM
amarjr's Avatar
Default Front Suspension: Crossbeam Retainer
Thanks for responding. Am I correct that the bolt must be missing for this retainer to have fallen out?
Sound like this could be pretty important and indicate that the bolt / screw could be missing. Or am i misunderstanding?
Does car need to be towed to shop for repair?
I did just find it paging through SNG Barratt catalog section for x308. page 53
It is Retainer, Genuine Jaguar part, Product Code:MNC2298AA, Special Order $11.28 plus shipping.
Old Feb 5, 2024 | 02:32 AM
Sean B's Avatar
Nothing to be concerned about, it's basically a plastic bung to stop water/dirt entering the subframe, the bolt it covers will be torqued up.
Old Feb 5, 2024 | 08:45 AM
amarjr's Avatar
Thank you motorcarman and Sean B. Really helpful.
Great forum!!!
Old Feb 6, 2024 | 09:33 AM
I was lying in bed last night and realized that the bolt I was remembering was the MOTOR MOUNT BOLT, not the body bolt.
The bolt part number is JFS11035E and I think it is a T40 or T45 TORX.
Sorry for the confusion.
Old Feb 6, 2024 | 11:19 AM
amarjr's Avatar
Does this mean I need to get car to shop?
In SNG Barratt, p53 it looks like:
Retainer: MNC2298AA
Bolt: JFS11035E
Attached Thumbnails Mystery Part?, black plastic hose connector-sng-p53-s-s.jpg
Old Feb 6, 2024 | 12:46 PM
The bolt is not loose. Just the plastic plug fell out. It has nothing to do with the mount, just the cover of the bolt.
Aleather
Dec 13, 2023 05:21 PM
jaguar.x308.1997
Apr 22, 2022 03:58 PM
pixel
Mar 31, 2021 03:57 PM
Jon89
Jan 3, 2021 04:23 PM
Blue_XJ8
Mar 12, 2018 08:04 PM
