Need help on what this part is? Pic included
Old Apr 12, 2011 | 10:57 PM
theusualsuspect's Avatar
Default Need help on what this part is? Pic included
Hello all,
I have 2 questions for you guys. My independent shop cannot find this part for me. They called it an alignment bushing or something along that line. I have a slight camber issue in the front left and am wearing out the inside of my tire too fast. They told me they were confident if this part was repaired and then an alignment was redone it would fix the camber issue. In the pic provided it is the part directly to the right of the second spring from the top in the pic and to the left of the 5 edged bolt..sorry not great the part names lol..and sorry this is a cell phone pic..
http://i5.photobucket.com/albums/y17...ORDANS/133.jpg
second question is if this fails to fix the camber issue they suggested a camber kit that looks to bolt on somewhere. They said that would fix the issue as well, but if the first pic has a broken part as well I would like to get that fixed..just need to know what it is so I can find it online and have them install it...much cheaper than the dealership and they are good, hardworking people
Old Apr 12, 2011 | 11:47 PM
Dan R's Avatar
This looks like a rear lower control arm bushing and the bolt that secures it is adjustable for alignment. The bushings are readily available from online stores eg, Autohaus.
I am surprised that your indy could not find them. Were they talking about fitting a control arm with the bushings already in it?
Old Apr 12, 2011 | 11:56 PM
hmmm well at 66k miles which was 11k ago for me I had the lower control arm bushing on the left side replaced? possible I got screwed over with a crappy repair?
Old Apr 13, 2011 | 07:31 AM
xjrguy's Avatar
That looks like a poor aftermarket replacement bushing or possibly just a rubber insulator stuffed behind the lower arm in an attempt to shore it up. Attached is a bulletin with part numbers to help get the right part.
Good luck!
File Type: pdf
Old Apr 13, 2011 | 07:48 AM
jimlombardi's Avatar
Default Diagram & Info on 2002 VDP Front Suspension
Hi theusualsuspect
I though you might like to have a diagram and other information about your 2002 VDP Front Suspension.
When PDF file opens in PDF reader - go to page 2 and view it in Full Screen Mode (menu option "Window" at Top of Screen). Use the "ESC" key to return to normal screen mode.
Here is a PDF file with diagram:
2002 XJ VDP Front Suspension Images.pdf
Here is information about possible replacement of bushings in the control arms.
Control Arm Bushing – Front Suspension
Labor Hrs 1.6 each side
Part Numbers
Upper Bushings CBC5523
Lower Bushings Front MNE1360AB Rear MNE1360BB
Old Apr 13, 2011 | 10:04 PM
thank you guys very much! I now know what I do not go to that independent Jag mechanic in tempe, AZ anymore. Really appreciate the help. Have a different independent that I trust now so I will take the car in soon.
Old Apr 13, 2011 | 10:23 PM
and i used your part numbers and came up with this..is this a good replacement? thanks..copy and paste the link to get it to work..thanks
JAGUAR XK8 XKR FRONT CONTROL ARM BUSHING MNE 1360AB NEW | eBay
Old Apr 13, 2011 | 11:53 PM
xjrguy's Avatar
Correct me if I'm wrong here, but it looks to me like you need [or were asking about] the REAR bushing on the lower control arm. The way I read it, that would be a suffix BB bushing, not a suffix AB, for a 2002 XJ.
Old Apr 13, 2011 | 11:55 PM
my fault just to clarify the problem is the left FRONT lower control arm bushing i believe..getting the car up on a rack friday so i will know more...would that link i provided work for the front left or is that an aftermarket bushing as well?
Old Apr 14, 2011 | 12:16 AM
Dan R's Avatar
I have used Uroparts bushing in the past and they are OK. Might use Jag ones in the future though. More durable perhaps.
Old Apr 14, 2011 | 02:35 PM
one last question for you experts..do you recommend I do the lower and upper bushing at the same time even if the upper looks to be in good condition? Just wondering if that will need replacing down the line and since the workers will be in there if its recommended to just do both...or maybe the upper is a tougher job..thanks
Old Apr 15, 2011 | 12:38 PM
Hi
I have deleted my posting here and moved it into a new thread
Sorry
Jim Lombardi
Last edited by jimlombardi; Apr 15, 2011 at 12:48 PM. Reason: moved this posting to another thread
Old Apr 15, 2011 | 03:29 PM
is 1.6 hours for the lower bushing and 1.9 hours for the upper bushing a good quote?
Old Apr 15, 2011 | 03:47 PM
xjrguy's Avatar
Well, Jaguar labor for both lower wishbone bushings, one side is 3.3, for both upper wishbone bushings, one side, it's 0.7. Personally I think the 0.7 is a little light for that job. I don't think they are out of line for that repair.
Cheers,
Old Apr 15, 2011 | 03:51 PM
plums's Avatar
You can use the warranty time allowances given in the pdf posted by xjrguy as a comparison.
Warranty time allowances are usually *lower* than those given for customer paid job.
The parts numbers for the various VIN ranges is also given.
Old Apr 15, 2011 | 04:27 PM
Hi
Alldata lists 1.6 hours each side. It does not break the hours down for the upper and lower wishbone bushings. Just total for each side. It sound low to me also.
Jim Lombardi
Old Apr 15, 2011 | 05:17 PM
well I also have a 1974 el camino that I probably have put 10k into through my shop so they help me out when they can...plus they recommended the jaguar indy that totally screwed me over with the previous lower bushing...anyone in the phx area stay away from jaguar joe in tempe.
Wolfy
May 28, 2024 08:06 AM
Doug
Feb 27, 2019 01:31 AM
XJsc-guy
Nov 23, 2015 01:56 PM
user 652867429824
Sep 5, 2015 12:53 PM
TC Johnson
Sep 2, 2015 09:30 AM
