Need Sunroof Slide Mechanism (HNA1752AA) Solution
Old Nov 9, 2019 | 04:24 PM
benfbrown's Avatar
Default Need Sunroof Slide Mechanism (HNA1752AA) Solution
Hello everyone,
I just bought (yesterday) my 4th R-Type...a one-owner 2003 XJR with 60,000 miles on it. It's so new (to me) that I haven't even taken a pic of it yet.
When I was driving it home, I opened the sunroof but the rear (smaller) panel was disconnected and wouldn't slide back in. I checked the forum (of course) and learned how to fish it out successfully. Well, once I had the main panel out, I could see that small arm with the pin on the arm of PN HNA1752AA (R sunroof slide) was significantly bent.
I tried to gently straighten it...but you know what happened (and I knew it would probably happen when I was doing it). So, now I need that small arm or most likely the entire slide but it has been discontinued.
Does anyone have any ideas on how to get this repair accomplished?
Thanks!
Old Nov 9, 2019 | 04:27 PM
King Charles's Avatar
https://www.coventrywest.com/
Old Nov 9, 2019 | 04:28 PM
benfbrown's Avatar
Good idea.
Old Nov 9, 2019 | 08:06 PM
motorcarman's Avatar
NEVER try to bend the arm!!! It is a CAST part!!!!
I always bend the fulcrum pin to get the same outcome.
The TILT/SLIDE mechanisms used to be about $83 each back when I worked at the dealer.
I called my buddy in the parts dept. about 2010 and found out that the price had gone to almost $300 EACH.
good luck with your search.
bob
Old Nov 9, 2019 | 08:26 PM
benfbrown's Avatar
bob
I was bending the pin...lol. Based on those prices, I'm guessing a bit of fabricating is in my future.
Old Nov 9, 2019 | 08:30 PM
Coventry West had the entire SR set up when I was looking a few years ago.
Old Nov 9, 2019 | 08:37 PM
jackra_1's Avatar
I believe this is what I used to repair my sunroof slides mentioned in this thread:
https://www.jaguarforums.com/forum/x...ir-how-129108/
Old Nov 11, 2019 | 07:10 AM
benfbrown's Avatar
Thanks but but it is from an X350. Looking at the parts list for the 308 and 350, the 350 has different parts.
Old Nov 11, 2019 | 08:12 AM
jackra_1's Avatar
I cannot help any further unfortunately.
I did purchase from Ebay a kit for Lincoln. I no longer have access to my original order on Ebay as it was too long ago.
Ok found the invoice.
I ordered from: The Sunroof Doctor,11574 W Farm Road 34, Walnut grove, MO 65770-9281, 417-788-2707
Item 2000-2002 Lincoln LS Sunroof Repair Kit Item Number WSRK
Old Nov 15, 2019 | 01:32 PM
andyrewj's Avatar
I have a X308 about to go to scrap. PM me if you want me to pull a part for you.
Old Nov 15, 2019 | 01:49 PM
benfbrown's Avatar
Much appreciated but I just got a sunroof assembly from a local scrapyard yesterday.
Old Nov 15, 2019 | 03:03 PM
I would pull the sliding roof parts and sell them before scrapping the car.
Old Nov 20, 2019 | 01:38 PM
XJR-100's Avatar
Andyrewj,
I’m a new member and don’t seem allowed to PM at present.
If the tilt/slide mechanisms are in good order I may have use for them.
Old Sep 23, 2025 | 05:27 PM
Lear45's Avatar
As information Coventry West closed in 2022.
I am trying to find a right side tilt mechanism for an 98 xj8 VDP. HNA1752AA
soundking3
Sep 7, 2017 08:07 PM
Azcat
Apr 27, 2017 05:17 AM
EChem
Dec 21, 2011 06:40 AM
obriendob
Dec 21, 2011 06:34 AM
