New Fuel Pump ..... will not accelerate
1998 XJ8L ...just put in a new fuel pump....car starts and idles fine. when I step on the gas the car bogs down and will not accelerate...if I "baby" the gas peddle the car will not bog down but takes forever to hit 50-60 MPH. HELP !
Welcome to the forum larry g,
I've merged your two identical threads and moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
MORE INFO??
As RJ237 asked, did you remove the fuel lines from the bottom of the tank??
People try to pull (HORSE) the tank into the boot area without disconnecting the lines.
This usually results in destruction of the lines.
bob
bob
FS[SouthWest]: 97 Jag xk8
lrg3isme
Mar 15, 2017 08:53 AM
