New Fuel Pump ..... will not accelerate
Old May 23, 2017 | 06:52 AM
larry g's Avatar
Default New Fuel Pump ..... will not accelerate
1998 XJ8L ...just put in a new fuel pump....car starts and idles fine. when I step on the gas the car bogs down and will not accelerate...if I "baby" the gas peddle the car will not bog down but takes forever to hit 50-60 MPH. HELP !
Old May 23, 2017 | 07:13 AM
Welcome to the forum larry g,
I've merged your two identical threads and moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
Old May 23, 2017 | 03:06 PM
RJ237's Avatar
It's possible you crimped the fuel line. Also, did you change the fuel filter?
Old May 23, 2017 | 08:54 PM
motorcarman's Avatar
MORE INFO??
As RJ237 asked, did you remove the fuel lines from the bottom of the tank??
People try to pull (HORSE) the tank into the boot area without disconnecting the lines.
This usually results in destruction of the lines.
bob
Old May 24, 2017 | 08:01 AM
larry g's Avatar
ok...I did crimp the fuel line. I fixed it and the car is running great. Thank you
lsbrodsky
May 15, 2017 01:01 PM
Lawrence
XJ40 ( XJ81 )
Apr 22, 2017 11:01 AM
Lawrence
XJ40 ( XJ81 )
Mar 29, 2017 11:10 AM
lrg3isme
Mar 15, 2017 08:53 AM
