Passenger door not activating lights
Old Nov 12, 2021 | 10:34 AM
3timejag's Avatar
Default Passenger door not activating lights
When opened, the front passenger door on my ‘98 VPlas will not activate ANY of the interior lights or courtesy light. All other doors are working fine. I looked for a fuse, but none are clearly for that purpose, that I can see….
Anyone ever had this issue?
many thanks in advance!
Old Nov 12, 2021 | 12:34 PM
Jhartz's Avatar
Dirty switch on the passenger door -- WD 40 and exercise it
Old Nov 12, 2021 | 01:36 PM
3timejag's Avatar
Thank you Jim, but I don’t see a “switch”…is it built into the latch?
Old Nov 13, 2021 | 07:05 AM
Vauxi's Avatar
It is inside the locking assemblty itself.
Old Nov 13, 2021 | 07:22 AM
3timejag's Avatar
By that, are we talking about the actuator, or is there another part in there I need to either repair or replace…many thanks
Old Nov 13, 2021 | 07:25 AM
3timejag's Avatar
Is this what I need to replace?
Old Nov 13, 2021 | 07:27 AM
3timejag's Avatar
…or this..
Old Nov 16, 2021 | 10:57 PM
Vauxi's Avatar
The latter one. Not the door module.
Old Nov 17, 2021 | 07:52 AM
3timejag's Avatar
Thank you
Old Nov 17, 2021 | 08:46 AM
eliotb's Avatar
I hope you got this sorted out. Several months ago I had the latch in the driver’s door replaced because the microswitch was bad, causing a battery drain. I had a warranty replacement battery after the previous new battery failed. I am embarrassed to say I did not look to see if the rear reading lights were left on from the failing microswitch, which could have been where the current was going. Latch replaced with a remanned unit as new is NLA, but the problem promptly resolved.
Old Nov 17, 2021 | 08:52 AM
3timejag's Avatar
Thank you so much.
King Charles
Mar 18, 2017 07:20 PM
smachell
Jun 19, 2014 08:59 AM
Cadillac
XJ40 ( XJ81 )
Aug 7, 2009 12:53 PM
Stevel39
Jan 22, 2008 07:15 PM
beatch
Nov 21, 2007 04:15 PM
