Passenger window going down on its own
Old Jun 12, 2015 | 09:29 AM
sh500's Avatar
Default Passenger window going down on its own
Hi all,
I have this problem where the passenger window just goes down on its own without me doing anything. When it first started to happen, I was able to use the passengers own window rocker switch to close the window. It would happen randomly whilst driving.
More recently, the problem seems to have got worst, the window almost alway goes fully down when I start the car ( and more frequently when driving). The only way now that it goes up, is by holding up BOTH the rocker switches on the passenger side AND driver side master control (for the passenger window).
Any ideas if something just needs to be reset or if the actual switch is faulty, or even a connection issue?
Thanks.
Old Jun 12, 2015 | 09:38 AM
CharlzO's Avatar
You could try the battery reset, and see if that helps. Otherwise, try disconnecting the window switches themselves. Start with just the switch on that door, see if still does it. Then try the driver's switch by itself. Then both. Sucks to have to pull apart to check it (not that it's THAT hard but still).. that might narrow it down.
Old Jun 12, 2015 | 09:52 AM
test point's Avatar
Originally Posted by sh500
. . . goes fully down when I start the car ( and more frequently when driving).
I know this is going to sound strange but the first thing I would do is to have a free charging system test at your local auto parts store. That's easy. Window memory is the first thing to go with low battery voltage.
Then you can do all the other stuff.
Old Jun 13, 2015 | 04:32 AM
sh500's Avatar
I had the battery reset soon after I posted. Disconnected the terminals,left for about 5 mins but same thing.
I also decide to remove the door trim panel. Disconnected the rocker switch connector, reconnecting it, I can hear a single click, but the switch wasn't doing anything. For whatever reason, when I removed the panel, and started the car, the window didn't go down on its own. I think this just may have been coincidence perhaps.
Would a problem with the battery prevent the switch working at all though? All the other window switches work fine. It's a relative new, Bosch battery. Replaced about 2-3 years ago.
Should have said, I'm in the UK. I don't believe we get such free test.
Old Jun 13, 2015 | 05:02 AM
andrew lowe's Avatar
Don't just disconnect the battery, do a proper hard reset!
If you don't know how... search on the forum, there are a few instructional threads.
Old Jun 13, 2015 | 05:54 AM
test point's Avatar
He means to touch the negative CABLE to the positive battery POST.
Old Jun 14, 2015 | 12:24 PM
sh500's Avatar
It seems like after opening up the door panel and removing the connections, the window going on down on its own has stopped.
Also just tried the 'hard reset', but that hasn't made any difference.
Old Jun 14, 2015 | 06:11 PM
CharlzO's Avatar
Not sure off the top of my head if the connectors are the same between the front and rear doors, but i guess you could see if they're the same, and swap the switch from the rear to the front door, and vice versa, see if the problem follows the switch?
Old Jun 16, 2015 | 06:40 AM
sh500's Avatar
I don't think my last message got sent for some reason.
I was saying that I may just purchase a replacement switch. The existing one, seems to only close the window but not open it.
Old Jun 16, 2015 | 10:30 AM
CharlzO's Avatar
Ah, well seems like it's narrowed down pretty well, hopefully that's all it takes to correct it
Old Mar 9, 2019 | 09:13 AM
Redbaron536's Avatar
Hi. I have the exact same problem on my X-300. Thankful for a hint of you finally solved the issue.
// Jan
Old Jul 15, 2020 | 07:22 AM
sh500's Avatar
Forgot to update this post.
It was a replacement window rocker switch that resolved this issue
kevinl
Oct 31, 2019 06:15 PM
kurtomatic
Sep 26, 2015 10:31 PM
swetnK
Sep 23, 2015 10:49 AM
srpope80
Sep 23, 2015 09:23 AM
andytork
Sep 22, 2015 07:01 AM
