Pcv valve part number?
Old Sep 20, 2023 | 12:06 PM
Joe Enge's Avatar
Default Pcv valve part number?
The internet is not being nice to me today. I can’t find the Pcv valve for my kitty.
2000 xj8 vdp L, non sc
im getting banks too rich codes, so I’m working down the list. Oil is seeping anyways, so wouldn’t hurt to replace. Think there may be a grommet too?
I can find s types and the 2003 series, but not the ones for this.
can anyone point the way to me?
I appreciate you and your wisdom
joe
Old Sep 20, 2023 | 02:37 PM
Addicted2boost's Avatar
No PCV valve on any X308 cars.
Old Sep 20, 2023 | 02:40 PM
motorcarman's Avatar
There are only 'part-load-breather' and 'full-load-breather' orifices in the cam covers and tubing to the air intake.(no actual valve)
Old Sep 23, 2023 | 07:58 AM
Joe Enge's Avatar
Well, I look like an idiot. Good thing that I’m used to it.
when I looked up Pcv valve, it showed me things that looked like this. But think those were for a Jeep.
what is this and what does it do? It’s on both sides of the engine, both leaking oil. Not much, but enough to be annoying.
thanks for your answers, addicted and motorcarman.
Old Sep 23, 2023 | 01:00 PM
VVT actuator.
Old Dec 24, 2023 | 05:34 AM
ForTheLoveOfCars's Avatar
So i have a question then does wet spots around areas like this indicate a potential leak? Pertaining to a thread i made maybe week ago now i have a evap leak my full load breather seems to be either letting oil out or something because that area is not dry like it should be like when you spill a bit of oil topping up but not soaking wet either being this is on the side of the engine the oil filler is not i presume its letting oil out potentially under load gas cap is not as pretty as it should be but seals nice and tight also used some high milage oil to rehydrate the seal which worked great it allthough it closed well and tight before it very snug now as it should be my code was P0442 for reference
Quadcammer
May 19, 2022 03:09 PM
andymacsom1
Apr 16, 2017 12:39 AM
Spikepaga
Jan 31, 2014 03:53 PM
dockmaster
Jan 15, 2010 03:18 PM
Oldengineer
Apr 11, 2009 03:48 PM
