Power Window Issue XK8 Convert
Old Mar 29, 2019 | 08:21 AM
GregCPX's Avatar
Default Power Window Issue XK8 Convert
2003 XK8 Convert. The power window lowers as it should when you open the handle (from the inside or outside) on the drivers side but when you release the handle the window goes right back up. It does not stay down until I close the door like it should. This sounds like some sort of switch going bad but I could be wrong. Oh and I did "reset the windows" just to make sure. The passenger side is fine.
Thoughts?
Old Mar 29, 2019 | 08:54 AM
Addicted2boost's Avatar
This is the X308 board but, I’ll tell you what’s wrong with your window issue. There’s a microswitch that went bad in your door lock assembly. The door lock assembly is NLA. That leaves one to locate a microswitch and install it inside the door lock assembly. I would imagine when reposting this question in the X100 board that other members would direct you better.
Old Mar 29, 2019 | 09:05 AM
GregCPX's Avatar
HI Addicted,
Thanks for the update. I didn't even notice I accidentally posted into the wrong forum. Thanks for being nice about it...off to re-post.
-G
bklynchris
Aug 30, 2017 10:12 PM
Teesquare
Jun 12, 2015 07:25 AM
Leichardti
Sep 6, 2014 04:35 PM
keywasted
Jul 14, 2011 02:05 AM
JW
Feb 4, 2008 04:39 PM
