Primary Chain Parts Questions
Old Apr 29, 2012 | 11:47 AM
korvetkeith's Avatar
Default Primary Chain Parts Questions
1. Are these XJR compatible?
JAGUAR 1997-2003 V8 4.0L.THERMOSTAT,HOUSING.
JAGUAR 1997-2003 V8 4.0L.THERMOSTAT,HOUSING. COVER
2. Does the primary timing chain guide come with both the flat and curved side, so I'd need 2 of these?
2000 LINCOLN LS Parts - Tousley Ford Parts Depot
I've already done the secondary tensioners, and all of the associated upper gaskets and orings.
Now I intend to replace the:
Primary tensioners
Primary guides
Primary chains
Upper & Lower front cover gaskets
Front cover crank seal
Thermostat
Water pump
I'd like to replace the cooland hoses too. Do I need to get those from Jag? They weren't on christopher's site and I don't think they're compatible with Lincoln parts.
Am I missing anything?
Thanks a bunch
Keith
Old Apr 29, 2012 | 03:31 PM
Sean B's Avatar
Neither of those thermo housings will fit the XJR - it's a cast alloy part.
You will need 4 guides, flat and curved both sides.
Old Apr 29, 2012 | 08:01 PM
jimlombardi's Avatar
Hi
Here is a PDF file I created from JEPC (Jaguar Electronic Parts Catalog) and 2 websites (Britishparts.co.uk) and (Ebay Motors).
Shows XJR thermostat housing parts - Outlet Pipe & Cover
XJR (X308) Outlet Pipe & Cover (Thermostat Housing & Cover).pdf
Jim Lombardi
Old Apr 30, 2012 | 03:39 PM
Hello again
I created this PDF file that covers all the Primary Timing Chains related part numbers and prices. I used Christopher's Ebay webpages as a basis for getting the part numbers and the prices (also Gaudin Jaguar Parts website for the parts that did not have prices).
Page 2 in the PDF file has the list of parts and prices (Use zoom level of 100% in your PDF reader to be able view the part numbers clearly):
Jaguar V8 1997-02 Primary (Lower) Timing Chain Parts.pdf
The other 6 pages provided the part prices I used on page 2.
I hope I picked all the correct parts.
Jim Lombardi
way2far
Aug 31, 2022 09:26 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
hafren
Sep 2, 2015 06:22 PM
innzane
Sep 2, 2015 10:08 AM
TC Johnson
Sep 2, 2015 09:30 AM
