Problem with Fuel Filling
Old Dec 20, 2007 | 09:02 PM
jag_genius's Avatar
Default RE: Problem with Fuel Filling
probably a clogged close valve or pipe kinked not allowing pressure out..and let fuel in..
Old Dec 21, 2007 | 10:38 PM
dougs02's Avatar
You might leave a bit of a gap between the hose base and the tank fill and start filling slow and gradually increase the flow. This has worked for me before.
Doug
Old Dec 22, 2007 | 09:18 AM
jag_genius's Avatar
i would take the close valve off and see if it is tuck close..
Old Dec 22, 2007 | 07:17 PM
badmojo's Avatar
What does your gas guage say? I've had gas pumps that from time to time just keep shutting off and like doug says I have to pull back and fill slowly to keep the gas from backing up and shutting the pump off. How many times have you tried to fill it?
Old Dec 23, 2007 | 07:39 PM
dougs02's Avatar
Default Re: Problem with Fuel Filling
Sorry, but I had to delete my first reply because after I copied and pasted copyrighted material I realized I should not do that.
But what the material said is that the carbon canisters could be at fault if they have liquid fuel in them or kinked hoses.
Doug
Old Feb 13, 2008 | 10:51 AM
ken@britishparts.com's Avatar
Default RE: Re: Problem with Fuel Filling
This happens frequently with the Land Rover Discovery 2. A vent tube gets bent and does not allow pressure to release. I've never heard of it on an XJ8, but I would bet a shiney nickel that's where the problem lies.
toronadomike
Jan 22, 2026 10:13 PM
dsnyder586
Dec 29, 2024 07:39 PM
jdzubas
Oct 4, 2015 09:14 AM
alpecsa
Sep 7, 2015 11:55 AM
AL NZ
Sep 4, 2015 08:39 PM
