PSA : Cheap New Replacement FOBs
Old Mar 30, 2021 | 03:57 PM
  #41
Andre Reichert-Creutz's Avatar
Wow, exactly what I'm looking for. The original remote control of my X308 from 1998 is defective and cannot be revived. It's a LJA2610BA
Unfortunately, the eBay links for ordering no longer work. Do any of you have an address for me? That would be great
André
Old Mar 30, 2021 | 08:00 PM
  #42
Highhorse's Avatar
The second one is a repair service in the UK... https://www.ebay.com/sch/i.html?_fro...y+fob&_sacat=0
....https://www.ebay.com/sch/i.html?_fro...r+x308+key+fob
....use the part # off your fob, it will help dial in your search. The part # is important since its set to a frequency.
Old Oct 9, 2021 | 01:13 PM
  #43
Dickiederson's Avatar
Originally Posted by King Charles
So I bit the bullet & gave this vendor a whirl, it programmed 1st attempt & included the battery already installed. It also has a smaller footprint for less bulk in the pocket, I deem this a win for sub $50.
https://www.ebay.com/itm/For-1998-19...5/352437842314
I
i was so excited when I saw this but it looks like he no longer sells them… 😖
Old Aug 23, 2022 | 02:14 PM
  #44
Noah's Avatar
Hello, I'm reviving an old thread here to ask if anyone has recent success using an aftermarket fob to replace their non-working Jaguar fob in the US? The ebay links in the thread no longer take you to an active listing or help identify the vendor. This is for a 2002 XJ8/Super V8 in the USA market. The back of mine reads LJE2610AB - CWTWB1U322 - CAN 1788 102 354.
A search for CWTWB1U222 or LJE2610AB on ebay or google pulls up some cheap options like the link below but when you look at each listing for compatibility it actually says it's not compatible with Jaguar. Or the search brings up used Jaguar fobs which may be an option I'll explore. Or does anyone know of a company offering fob repair in the US? My car came with 2 fobs and 4 tibbe keys. One fob works some of the functions and the 2nd one doesn't work at all even with fresh batteries. Thanks for any input. Cheers.
https://www.ebay.com/itm/29304520446...3ABFBM2p7bwNlg
Old Aug 23, 2022 | 09:10 PM
  #45
Highhorse's Avatar
Are you using (2) 2016 batteries or (1) 2032? Review this if your using 2016's....https://www.jaguarforums.com/forum/x...pgrade-210090/
Old Aug 24, 2022 | 03:08 AM
  #46
RandyS's Avatar
Yes indeed, a 2032 works far better than doubled 2016s. and seems to cause no ill effects.
Old Aug 24, 2022 | 07:25 AM
  #47
xalty's Avatar
2001 and later is ford 4 button
before is the special remote
can’t find super special remote? change the slm to a newer one
Old Aug 24, 2022 | 08:36 AM
  #48
RandyS's Avatar
You can find the original style fob for as little as $25.
GENUINE OEM JAGUAR KEYLESS REMOTE REMOTE CONTROL FOB CWTWB1U322 XR83-15K601-AA | eBay
  #49
Noah's Avatar
Thanks for the responses. I'm using a single 2032 battery.
@xalty, thanks, I'll try one of those Ford 4 button remotes for my 2002. Do you know if I would need to program my existing remote (the one that works for some functions) at the same time I'm programming the Ford 4 button one?
Old Aug 25, 2022 | 12:40 PM
  #50
vincent661983's Avatar
but this one only works with post 2000 model year X308s
Old Aug 25, 2022 | 02:35 PM
  #51
leaddog11's Avatar
Interesting discussion
if your programing 3 how many times then to press the buttons each?
Old Aug 25, 2022 | 02:49 PM
  #52
motorcarman's Avatar
The same remotes will work for the 4.0 X100 coupe/conv Jaguars.
Same FOBs for the MY as the X308.
Old Aug 27, 2022 | 11:47 AM
  #53
David N. Warner's Avatar
The XJR I bought recently had this same aftermarket key FOB and it works just fine; better than the original one. It has a 2032 battery inside
Aftermarket FOB.
Old Sep 2, 2024 | 04:36 AM
  #54
IPBR21054's Avatar
Morning,
Im looking for some clarification please as per my post above im looking for another remote for a spare.
My existing remote is LJA 2610 CA 315MHz
I have found the following LJA 2610 AA 315MHz
Can you advise if the item i have found will be compatible / work for me.
Many Thanks
Old Sep 2, 2024 | 09:10 PM
  #55
Highhorse's Avatar
The CA is an update of the AA, you see this a lot on automotive parts. It could be anything from different plastic to better cold solder points.
If you want to reference fitment, use this... https://jaguar.oempartsonline.com/oe...tter-lja2610ca
May I suggest you also put your location, MY and other info in your signature so we know what you have to reference. We get folks who post in the wrong forums also and want to be sure to direct them and provide info appropriately.
Old Sep 3, 2024 | 02:55 AM
  #56
IPBR21054's Avatar
Hi,
Im in the correct group & i am going by the remote i have.I am looking for a customer of mine which has the remote 4 button lja 2610 ca 315MHz
As mentioned the one my supplier has sourced is LJA 2610 AA 315MHz
Thanks so sounds like it is correct
He has a working item & needs a spare
Old Sep 3, 2024 | 08:53 AM
  #57
RandyS's Avatar
Originally Posted by IPBR21054
Hi,
Ahhhh...yes. Thanks so much for visiting our humble forum. We certainly
hope we can aid you further in your various endeavors.
Old Oct 15, 2024 | 02:40 PM
  #58
Splerk45's Avatar
After some sleuthing, here is the likely SLM cutover VIN. The later SLM goes for about $150 USD on eBay. The earlier ones are about half that.
So if you have an earlier SLM, you could spend $150 on an SLM so you can use a pair of $8 Fobs.
EARLY KEY FOB FCC ID K8597T315
SLM LNC2600HE 812317-F20644
SLM LNC2600HF 812317-F20644
CHEAP FORD KEY FOBS CWTWB1U311 / 22
SLM LNG2600HB F20645-F59525
Source: https://partsfan.com/jaguar/ww
GordoCatCar
Jul 29, 2024 11:00 AM
Highhorse
Oct 21, 2019 12:11 PM
redxk8
Sep 30, 2015 08:18 AM
marktmv
Nov 2, 2008 08:02 PM
smileboot
Apr 27, 2007 11:05 PM
