Rad removal - ac as well?
Old May 14, 2013 | 10:27 AM
John Tarantula's Avatar
Default Rad removal - ac as well?
Hello! sorry my third post is a question!
Just got a 2001 XJR and the engine coolant is leaking out from the bottom of the rad. Have a replacement rad to fit in but the workshop manual it says I need to remove the AC pipes and depressurise the system to get the rad out. It is possible to get the rad out without doing this as don't really want to have to regass the AC unless I have to. thanks!
Old May 14, 2013 | 01:25 PM
Sean B's Avatar
You can do it without cracking the air con, problem is the condenser is bolted to the front of the rad. Grill and front bumper off to make space to get at it.
Hope this helps.
Old May 14, 2013 | 02:09 PM
sparkenzap's Avatar
I agree, it is not too bad. Be careful of the mounting clips and bolt clips, though- they get brittle.
Old May 14, 2013 | 05:22 PM
OK cheers guys, will have a proper look once it stops raining for a bit! the replacement rad i have looks like it has the ac pipes going in and out of it so hope I've been sent the right one!
Old May 14, 2013 | 05:41 PM
the pipes I'm confused with are these two circled to the left:
if they are for the AC how do you swap the rad without depressurising the system? unless they are for something else? haven't taken the existing rad out yet so might become clear then!
Old May 14, 2013 | 05:57 PM
plums's Avatar
transmission cooler
Old May 14, 2013 | 06:51 PM
ah splendid! that saves me a lot of headache, thank you!
Old May 14, 2013 | 09:47 PM
sparkenzap's Avatar
yep, and blow them out pretty good, maybe even flush them is they have been open for ag while.
Old May 15, 2013 | 05:24 AM
Cool, will give the rad a good flush too before fitting
Old May 15, 2013 | 06:59 AM
xjay8's Avatar
A 2001 XJR...probably high mileage...I would tend to do it the easy way and remove both the rad and A/C....as most likely at this stage of it's life it would need a purge and re-gas anyway....kill two birds and all that.
Damn sight easier than faffing about and running the risk of damaging pipes and fittings.
Certainly cheaper in the long run and you have a good A/C to boot ;o)
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
Wahooesprit
Dec 23, 2019 02:01 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
mhamilton
Sep 12, 2015 03:21 PM
