Rear differential replacement DIY?
Old Apr 16, 2014 | 04:38 AM
jimlombardi's Avatar
Don B post mentioning the Jaguar Classic Parts differential diagram sparked my interest.
"The parts diagram at jaguarclassicparts.com clearly shows a fill plug on the back cover of the X308 diff."
Look at number 7 Female Plug's location and number 3 Differential Case Breather on the diagram:
Here is the weblink to their webpage showing the Differential Assembly:
Differential Assembly - Parts For XJ Series from (V)812317 to (V)F59525 (X308) | Jaguar Classic Parts UK
Here is another weblink to the only other information I could on the internet about the differential (look at post #8 talks about the differential case breather):
https://www.jaguarforums.com/forum/x...al-leak-38375/
Jim Lombardi
Old Nov 28, 2014 | 09:28 PM
Michael Hunter's Avatar
Hi there!
I am getting ready to do the differential transplant on my 2000 XK8 in my garage. I really appreciate all the information about jack stands and 2X6 "skies".
I have been told that you need a fancy-dancy spring compressor to do this job. I saw no references to a spring compressor in the various posts on this subject.
What can you folks tell me?
Thanks!
Michael
Old Nov 29, 2014 | 02:13 PM
Heliwilly's Avatar
Question XJ8 Diff
I am in the process of replacing the diff on my 2001 (Nov) XJ8. The problem I have is that the replacement I have acquired has, at some stage, been dropped and damaged two of the studs that the half shaft bolts on to. How easy is it to remove the output shaft to replace these studs.
Thanks. Bill W.
Old Nov 29, 2014 | 10:25 PM
dsnyder586's Avatar
Hi Michael,
You only need the fancy spring compressor for the front. The rear end will come out whole, along with the springs and shocks if you like depending on what you remove. I found it easiest to remove the entire rear with the exception of the brake calipers and working on it while it was on the ground.
Old Dec 4, 2014 | 12:35 PM
Thanks to all of you for your advice and encouragement (?). The car goes under the knife in a couple of hours.
I will let you know how it turns out!
Michael
BrentGardner
29
Dec 16, 2024 12:13 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
plums
General Tech Help
Sep 1, 2015 06:34 AM
mrplow58
Aug 29, 2015 10:44 PM
dpappyp
Aug 27, 2015 06:31 AM
