Rear Electronic Module
My rear (RH) blinker started acting up (fast blink and warning light) in cold weather on my '04 XJR. Replacing the bulbs didn't solve the problem so I bought a used Rear Electronic Module (REM) with the identical PN# and tried swapping it out. No luck, made things worse so I am guessing it needs to be programmed for my specific vehicle. I thought this would be a slam dunk, so I drove down to the Jag dealer with my VIN# and new REM where I was told they no longer service vehicles older than 2013. I wasn't ready for that so now I need to find a place that can reprogram the REM for my car as optioned. Question is, has anyone run into a similar problem? If so, where can I send the REM for programming? Thanks in advance for any helpful suggestions.
My bad. Posted on the wrong forum. Have since re-posted. Thanks for the heads-up motorcarman.
Ehrmantraut
Oct 8, 2019 10:13 AM
KKostas
Aug 23, 2013 09:47 PM
slay100
Aug 26, 2010 12:55 AM
