Rear Electronic Module
Old Nov 30, 2022 | 07:13 AM
russpe's Avatar
Default Rear Electronic Module
My rear (RH) blinker started acting up (fast blink and warning light) in cold weather on my '04 XJR. Replacing the bulbs didn't solve the problem so I bought a used Rear Electronic Module (REM) with the identical PN# and tried swapping it out. No luck, made things worse so I am guessing it needs to be programmed for my specific vehicle. I thought this would be a slam dunk, so I drove down to the Jag dealer with my VIN# and new REM where I was told they no longer service vehicles older than 2013. I wasn't ready for that so now I need to find a place that can reprogram the REM for my car as optioned. Question is, has anyone run into a similar problem? If so, where can I send the REM for programming? Thanks in advance for any helpful suggestions.
My bad. Posted on the wrong forum. Have since re-posted. Thanks for the heads-up motorcarman.
Old Nov 30, 2022 | 08:58 AM
motorcarman's Avatar
X308 sedans do NOT have REMs.
Post in the X350 sections.
Old Nov 30, 2022 | 09:08 AM
russpe's Avatar
Ah. Right you are. Duh! Thanks.
Old Nov 30, 2022 | 09:35 AM
RandyS's Avatar
We seem to attract quite a few of these postings that belong elsewhere.
JansJags
Jan 29, 2021 12:21 PM
Ehrmantraut
Oct 8, 2019 10:13 AM
mateis123
Mar 3, 2015 08:55 AM
KKostas
Aug 23, 2013 09:47 PM
slay100
Aug 26, 2010 12:55 AM
