Rear Shock Job Bits
Old Apr 30, 2025 | 08:04 AM
mayhem's Avatar
Default Rear Shock Job Bits
Gathering parts for the rear shocks in my non-CATS 01 XJR. Pair of new green Bilsteins is obvious and I believe it comes with everything inside the box labeled 7 (below) , what about other common wear parts that ought to get replaced while its all apart?
Is it just part #4, the upper spring isolator that's the common wear part and all the rest is metal? I can get OEM Jag ones for $50 each.
Thanks!
Old Apr 30, 2025 | 09:06 AM
motorcarman's Avatar
The spring isolator will not be included with the replacement dampers.
I have a 2000 XKR that the previous owner had new dampers installed BUT they re-used the old spring isolators.
The whole job needs to be redone to replace them. (not happy)
Old Apr 30, 2025 | 09:43 AM
RandyS's Avatar
There are so many things like this that could have been engineered
so much better.... I always like to think of the engineering changes
that could have been made to make things such as this a much more
cost effective and prudent arrangement.
Old May 1, 2025 | 04:21 AM
57loboy's Avatar
#4 is all you’ll need. Bob’s older post on how to do the shocks the “easy” way is spot on. The shock/spring assemblies DO quite literally fall out that way. Took me about 45 min per side as a “first time ever” job.
Old May 1, 2025 | 07:20 AM
mayhem's Avatar
Thanks guys!
mike32966
Mar 2, 2025 02:58 PM
Mr rx-7 tt
Dec 13, 2021 05:05 PM
impster
XJ40 ( XJ81 )
Jan 12, 2021 08:51 AM
97XJR-Flausa
May 31, 2017 12:54 PM
EZDriver
Sep 8, 2015 09:25 AM
