Repaired my sub woofer today!
Old Jun 8, 2012 | 06:41 PM
LaserSVT's Avatar
Lmao!
Old Jun 8, 2012 | 09:01 PM
ixj8it's Avatar
lol thats the funniest thing I have seen on jaguarforums in a while
Old Jun 8, 2012 | 11:28 PM
mechelement's Avatar
Originally Posted by Vector
It's a 6x9 dual voice coil sub, 4 ohms IIRC. Very hard/expensive to find a replacement, that is why I did the repair.
Vector
Any more specs on that sub? What's the frequency range? Is it a true 6x9 subwoofer, or is it a 6x9 speaker w/ dual voice coils?
Old Jun 9, 2012 | 12:58 AM
QuadManiac's Avatar
This unit in the Jag is intended to be used as a sub, distributed by Alpine, and it is 6x9 format with dual voice coils. Can't quote a frequency range, but I can tell you it has poor high frequency and pretty good low frequency response.
The Retrosound dual VC 6x9's do not have the low frequency response nor the throw that we need... they're rather poor full range speakers with co-ax tweeters designed to play a stereo signal from a modern head unit in a car (like a 65 Mustang, for instance) that has a single 6x9 opening in the dash or parcel shelf.
Old Jun 9, 2012 | 09:02 AM
Do you know if the OEM Alpine 6x9 is actually a speaker and not a sub? Knowing the actual frequency would be great. Do you think it's along the lines of 30Hz - 21kHz? Is it low profile?
Old Jun 9, 2012 | 11:56 AM
LaserSVT's Avatar
A sub is a speaker. The cone is not capable of playing down to 30hz. No cone that size can. Its -6db roll off is prolly near 45hz. It does a respectable job for what it is and plays deeper than any other 6x9 I have ever heard and I did car stereos for over 15 years with well over 4000 installs.
As far as getting to 21khz? Not a chance. Maybe 500hz at best. Most tweeters can not play that high. Besides the human ear generally can not hear sounds above 20khz.
Old Jun 9, 2012 | 12:34 PM
burmaz's Avatar
I have a used sub I got from a junkyard from a '02 XJR that has been sitting in my trunk for years as I have not gotten around to installing it. The foam surround is fine, but would you guys recommend that I use a speaker repair kit anyway since the speaker is 10 yrs old?
Old Jun 9, 2012 | 05:57 PM
  #28
Vector's Avatar
Considering what a PITA it is to do the replacement, I would install a new surround before you install the sub.
Vector
Old Jun 9, 2012 | 06:39 PM
LaserSVT's Avatar
Vector
+1
trosty
Dec 17, 2021 07:41 AM
Rivguy
Dec 4, 2020 07:55 AM
JagBrian
Aug 18, 2019 05:07 PM
RaceDiagnostics
Nov 10, 2015 11:05 AM
sonofdave1980
Sep 14, 2015 07:45 PM
