Replacing brittle plastic vent hoses
Old Jul 13, 2010 | 01:04 PM
jaginblack's Avatar
Question Replacing brittle plastic vent hoses
On my engine there are runs of black corrugated hard plastic hose with quick disconnect fittings (engine ventilation) and I would like to replace them all. In some areas they have become brittle enough to break at a slight touch and I am at a point where I could access them all easily.
Does anyone have a source for the fittings and bulk hose, same material or equivalent, so that they can be made to fit? Otherwise, does any vendor carry the complete set for my '01 AJ27?
I have been searching the web to no avail... Thanks.
Old Jul 15, 2010 | 06:25 PM
jaginblack's Avatar
I did find a manufacturer which listed the hose and the fittings (called Norma connectors), but so far no mailorder source, other than one pre-made replacement section (luckily the one I broke), but not the other section and I would like to replace all of it.
Anyone have any clues on these hoses?
Old Jul 15, 2010 | 06:53 PM
orca99usa's Avatar
I broke one of mine changing the air filter. Try Motorcarsltd.com for your parts. That is where I got mine.
Old Jul 15, 2010 | 06:54 PM
jaginblack's Avatar
Here is the only section I found to be ordered... but where to get the rest of it? This piece is appx $35 from RedLineMotive.com.
http://www.dropbox.com/gallery/5992274/1/Hose?h=c6e48f
Old Jul 16, 2010 | 10:10 AM
jaginblack's Avatar
I have added a couple of pics of the hose assembly I am trying to locate or somehow replace. It is the Injector Air Assist circuit, running from the throttle body to the injector rails. Colored yellow in the pics.
The other hose pictured I have located. That one is the Part Load Breather hose.
If it wasn't for the quick connectors being hard to find I would just remake these hoses...
Old Jul 20, 2010 | 06:35 AM
jaginblack's Avatar
I was able to source the Injector Air Assist hose from Dan@JagBits.com - $65 new. So including the new Part Load Breather hose about $100 total.
Thanks all.
Old Jul 20, 2010 | 07:27 AM
H20boy's Avatar
good find, now be careful under the bonnet!
Old Jul 20, 2010 | 10:06 AM
JimmyL's Avatar
Red face Hoses
I'm just curious, can you replace the part breather hose without removing the intake manifold ? I've got a new one sitting on the shelf, but looked at where it disappeared and decided to put that job off for a while.
Old Jul 21, 2010 | 07:59 AM
jaginblack's Avatar
It does run under the manifold, but I couldn't say whether or not it could be replaced without pulling the top off. It wouldn't be as easy, that's for sure.
Forcedair1
Sep 8, 2025 01:57 PM
KarimPA
Sep 3, 2015 07:32 PM
davidladewig
Sep 3, 2015 06:32 PM
d a
Sep 3, 2015 02:34 AM
OkieTim
Sep 2, 2015 12:48 PM
