Replacing front shocks
Old Apr 8, 2018 | 05:06 PM
edreddy's Avatar
Default Replacing front shocks
: OK - am I missing something when it comes to replacing the front shocks? I have taken off the upper shock housing, but I can’t seem to slide out the shock. Do I have to remove the sway bar end links?
ed: figured out. You need to compress the shock
Old Apr 8, 2018 | 05:57 PM
Andmars's Avatar
Took me a while to figure that out too, push it up fully to compress, then remove it quickly. To refit compress the shock fully, then quickly stick it into the top mount before it expands again. Like most things, its easy when you know how
Old Apr 8, 2018 | 08:22 PM
edreddy's Avatar
let me tell you how much of a PITA it is so do on cold shocks.
A few bumps and scraps later, front shocks done. Bump stops look like they were replaced recently.
Old Apr 8, 2018 | 09:44 PM
CharlzO's Avatar
I agree there. Compressing them and giving yourself those precious seconds to get them in place is a trick. I also found, that even one last inch of drop in the suspension travel makes a world of difference!
cjd777
Apr 17, 2014 06:33 PM
ehaglund
Oct 18, 2012 11:29 AM
rocklandjag
Jun 11, 2011 11:42 PM
mmolaik
Sep 21, 2010 02:44 AM
jcharp
Mar 1, 2010 05:10 AM
