Restricted performance after trans
Old Dec 8, 2011 | 10:11 PM
ant17's Avatar
Default Restricted performance after trans
Just had my ZF trans replaced and now I get restricted performance.
Can't get a read on codes.
Any idea what it can be?
Everything seemed to be connected, did a hard reset.
Still restricted, engine running rough. Never did before.
TIA
Old Dec 8, 2011 | 11:58 PM
sparkenzap's Avatar
Swapped O2 leads? What do you mean "can''t get a read on codes"?
Old Dec 9, 2011 | 04:39 AM
yeldogt's Avatar
What codes are you getting?
This RP is very baffling ..... When my car has had the issue it will sometimes run rough as if it is having a coil problem. But after immediately restarting and getting no RP the car will run normally.
My only thought is that RP must put many of the cars systems into a "base mode" where the only concern is to allow the car to be moved to a safe location regardless of what sensors failed.
In my case I think it is the TPS -- it causes a signal loss on the CAN ... and RP.
Since the transmission is also on the CAN -- maybe you have an electrical problem?
Old Dec 9, 2011 | 05:39 AM
ant17's Avatar
Couldn't get my elm 5 to connect, I'll go to autozone and see what's up.
Old Dec 9, 2011 | 06:39 PM
ant17's Avatar
Codes:
1. P 1722
2. P 1316
3. P 1000
4. P 0732
5. P 0175
6. P 0171
7. P 0308
8. P 0307
9. P 0300
I suspect that the O-2 sensors may be switched.
Checking it out now.
Trans was causing trouble before replacement, but engine always ran perfect at all times!!! Not no more.
Old Dec 9, 2011 | 07:32 PM
xjrguy's Avatar
Originally Posted by ant17
Codes:
1. P 1722
2. P 1316
3. P 1000
4. P 0732
5. P 0175
6. P 0171
7. P 0308
8. P 0307
9. P 0300
P0171 and P0175 together point to the possibility of switched O2 sensors.
P1722 and P0732 suggest a remaining trans mechanical fault, UNLESS they were never cleared once the trans was repaired/replaced.
Cheers,
Old Dec 9, 2011 | 10:24 PM
ant17's Avatar
Cheers,
The trans fault codes were not cleared after replacement.
I looked at the O2 sensor plugs, unplugged them but not sure I switched them.
Had all unplugged at once.
Old Dec 10, 2011 | 05:25 AM
sparkenzap's Avatar
I assume you have the JTIS schematic to ID the correct connections-
Old Dec 10, 2011 | 06:49 AM
ant17's Avatar
I do, trying to locate on the CD.
Old Dec 10, 2011 | 09:18 AM
sparkenzap's Avatar
Upper right on diagram 4.1. page 54 of electrical guide, accessed through the wiring looking icon, then section 4 (electrical), at least in my version 1.3). The U wire refers to blue, the UY refers to blue with a yellow stripe- R is red and so on. Its a little complicated to describe the wiring for each, so its best you have a look at it.
Old Dec 10, 2011 | 09:33 AM
sparkenzap's Avatar
See if this helps- A Bank is right side, of course
Old Dec 10, 2011 | 10:42 AM
ant17's Avatar
Update:
Got the code reader going and cleared all the trouble codes.
Last night found a crack in the small flex hose to air intake, taped it with electrical tape.
Cleaned the TB, wasn't too dirty, and switched 2 of the O-2 sensor plugs.
RP is gone, car seems to be running fine, opened it up on the main road and had good pickup and speed.
Old Dec 13, 2011 | 10:57 AM
xjrguy's Avatar
Update:
Good job!
Chalk up another one to JaguarForums.com!
Old Dec 14, 2011 | 05:27 AM
ant17's Avatar
Good job!
Yes, Indeed!!
Delta66
Oct 4, 2015 05:40 PM
Johncy2000
Oct 2, 2015 01:05 AM
1100me
Oct 1, 2015 11:49 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
