Restricted Performance, jerky shifting...
Old May 8, 2012 | 04:52 PM
princemarko's Avatar
Default Restricted Performance, jerky shifting...
My XJR is dealing with a weird issue.... I can feel the car jerk when it shift gears in 1st and 2nd.... and it gets slightly worse for a week... then the Restricted performance light comes on, and it disappears almost immediately. The check engine light stays on for 2-3 days and goes away... and the process repeats every 2 weeks.
What do you think it is? Vacuum leak? Injectors?
Old May 8, 2012 | 05:57 PM
Sean B's Avatar
Have you plugged an OBD in? it'd be good to know what codes are thrown before we start guessing.
Old May 8, 2012 | 08:43 PM
I get codes that its running rich. Thats it. Then it clears itself up.
Old May 9, 2012 | 02:30 AM
plums's Avatar
As a first move, you could check that your transmission fluid is at the right level.
Then you could look at doing a transmission adaption procedure. There is a pdf around here that details the procedure.
Old May 9, 2012 | 08:44 AM
Transmission fluid level could trigger Restricted performance with codes that are saying its running rich?
Old May 10, 2012 | 04:03 AM
P0172 and P0175, running rich on both banks
Old May 10, 2012 | 04:57 AM
Sean B's Avatar
Cleaned the MAF sensor?
Old May 10, 2012 | 08:00 AM
cleaned it, is only a year old, pinched in the pins to make a better connection.... still same...
JaguarLover101
48
Jun 12, 2023 10:28 AM
Delta66
Oct 4, 2015 05:40 PM
Johncy2000
Oct 2, 2015 01:05 AM
Glenn Barickman
Oct 1, 2015 04:09 PM
