Restricted performance, rough idle.
Old Jun 20, 2018 | 02:27 PM
PlatinumXJR's Avatar
Default Restricted performance, rough idle.
2000 XJR Supercharged, 92K miles. After an overnight cold start engine runs smoothly and is responsive to acceleration. After about 15 miles, "Restricted performance" light comes on and engine idles roughly. I've cleaned the MAF sensor (with the spray application). My service techs tell me all 8 ignition coils are bad, even though we replaced one 3 months (1,500 miles) ago. Restarts after engine cools down and runs for up to about 12-15 miles and the "Restricted performance" light comes on and rough idling resumes.
Old Jun 20, 2018 | 02:38 PM
CharlzO's Avatar
Best thing to do is have the codes read, so we can see what's tripping it.
Old Jun 20, 2018 | 06:14 PM
avern1's Avatar
Getting the codes read is always the starting point. But try something.Start if from cold and as soon as the restricted performance kicks in open the boot and try to put your hand on the battery. Is it HOT, not warm but really feels hot. If so you may have an internal short in the battery that opens when hot and kicks off the restricted performance due to low voltage.
Old Jun 20, 2018 | 08:46 PM
JTsmks's Avatar
“My service techs tell me all 8 ignition coils are bad”. My advice is find new service techs. As others have said, pull any codes and go from there.
Old Jun 21, 2018 | 01:40 AM
JagV8's Avatar
+1 all 8 do not go bad at once!
Old Jun 21, 2018 | 10:49 AM
Jhartz's Avatar
You might also have a bad temperature sensor. Car enriches, it is cold, at start up, but sensor never tells the ECU that it is now warm to flow fuel at a reduced rate. Codes!!!
Might also try a fuel system cleaner (BG44K or equivalent) to see if that doesn't clean up the system. It is also very easy to pull the coils and run a cleaning tool where they touch the plugs. A few years back, an XK8 owner had the same problem, most of us were pretty sure it was bad secondary tensioners (jumped timing -- yours are the third generation, right?), wound up dirty electrodes . . .
But up the street, there is a really good Jag tech . . . Bob Goff.
Old Jun 23, 2018 | 07:41 AM
JagV8's Avatar
If Bob is near or nearish - arrange to see him!
Old Jun 24, 2018 | 05:17 AM
Iconoclast's Avatar
I have replaced 5 of my 8 ignition coils & it was over a period of several years. My OBD-II code reader told me exactly which cylinder was misfiring. It is fairly easy to DIY. There s/b threads here with photos.
Old Jun 24, 2018 | 07:52 PM
Default Restricted performance.
Thanks, CharlzO, Any idea of which code reader device iI should buy? I have an iPhone and understand there is an app that interacts with the code reader? Do code readers provide descriptions of the different codes?
Old Jun 24, 2018 | 07:59 PM
I took the car to where I bought the new battery (in January 2017) to have it checked for shorted cells/plates. It showed at 14+ volts and no shorts.
Old Jun 24, 2018 | 08:02 PM
It also never was HOT to the touch.
Old Jun 25, 2018 | 01:41 AM
JagV8's Avatar
Sounds like the alternator volts, not the battery.
Old Jun 26, 2018 | 08:09 PM
vincent661983's Avatar
I just had a similar situation two months ago throttle body got to be replaced
KenAdamson
37
May 26, 2020 04:40 AM
EnRoute30
Apr 15, 2017 10:39 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
Oct 8, 2012 04:24 PM
JimC64
Sep 10, 2009 12:44 PM
