restricted performance and won't rev above 3k
Old Apr 20, 2019 | 01:30 PM
RA110623's Avatar
Banned
Default restricted performance and won't rev above 3k
hi guys I changed the fuel pump after 5 hours of working on it my god the lines under the car is nightmare if you doing it for first time any way after changing the pump the car work but still show restricted performance and won't rev above 3k rpm I connected obd rearder and found these codes p0102 mass or volume air circuit low- p0122 intake air temperature sensor 1 circuit low - p0333 Knock sensor 2 circuit high Bank
I have read different threads about the knock sensor problem I think my car have faculty knock sensor what should I do ? change both of it? or it's fixable?
where should I start to fix .
in case my signature is not showing may car is 2002 xj8
thank you.
Old Apr 20, 2019 | 02:40 PM
Highhorse's Avatar
I agree on the knock sensor.... when mine went, it sucked when the restricted performance came on for it and she chugged hard each time I tried to apply descent pedal.
For replacement instruction, this link from Jim Lombardi is priceless.... https://www.dropbox.com/s/ti0842gz36...Y%20N.pdf?dl=0
The original thread for it is here, you'll note the alternate sensors used instead of the expensive X308 ones. I wound up using knock sensors for a 2005 4.2L, which is said for a XJ8, mine is an XJR and its been over a year with no issues.
Old Apr 20, 2019 | 04:13 PM
RA110623's Avatar
Banned
thanks ray for the link I checked the sensor in auroparts warehouse it's not 27$ I think that might be old price maybe?
the car still run fine below 2800rpm and shifts normal.
I will check how much is that 2005 4.2l Knock sensor because the knock sensor for my car cost 133$ in rockauto.
Old Apr 20, 2019 | 05:42 PM
Carnival Kid's Avatar
These Knock Sensors will fit the 2002 XJ8..........the cheapest I've seen any of them of late is around $85.00
Duralast SU7015 or SU7012
Airtex 5S5619
Standard Motor Products KS309
Denso LNE1692AA
Old Apr 20, 2019 | 07:54 PM
Highhorse's Avatar
Yeah, check the dates of those posts, you have to search because deals come and go. Even the ones I got from NAPA just a year ago aren't even showing up on their website (got them for $67 ea). The pricing CK is showing are pretty good, usually the cost is around $125+ ea.
Old Apr 20, 2019 | 09:15 PM
vincent661983's Avatar
check the spark plugs
Old Apr 21, 2019 | 02:20 AM
RA110623's Avatar
Banned
Airtex 5S5619
Denso LNE1692AA
thank you for help
do you think 2002 Lincoln LS knock sensor will fit into my car ? maybe with some connector modification?
Old Apr 21, 2019 | 02:25 AM
RA110623's Avatar
Banned
okay should I change both of them or just 1 ? and do you think more things gonna fail ?
Old Apr 21, 2019 | 07:44 AM
Highhorse's Avatar
No one can say what may or may not fail...as far as replacement, mine were almost necessary I replaced both since I have to pull my SC to get to them. For yours, they are readily accessible and if you only need to replace one, that is your choice. You may wish to buy both and replace one,...again, your choice. My attitude is, your there, why not do both....don't let it lapse that these are 17-23 yr old cars, parts will need replacement.
As for the Lincoln sensor...I do not know...perhaps someone with knowledge of that fitment will chime in?
Old Apr 21, 2019 | 10:03 AM
RA110623's Avatar
Banned
it's easy to change I will change both right and left side .
I think there's some engine parts from 2002 Lincoln LS and 2002 ford thunderbird that can fit into x308 jaguar
Old Apr 21, 2019 | 06:14 PM
Dutchy's Avatar
I'd change both sensors then you have deleted that problem your car is later than mine
but I thought one of those faults was the MAF when unplugged only went into Restricted mode
The AJ26 does have knock sensors I thought, (still learning about these engines)
Dutchy
Old Apr 21, 2019 | 09:24 PM
Highhorse's Avatar
Yes, the AJ26 does, but the sensor has a screw on cap vs the nut down version on the AJ27.
Sarahtonin
Jan 4, 2018 01:15 PM
kmarajh
Sep 4, 2017 09:07 PM
OldKingCole
XJ40 ( XJ81 )
Oct 29, 2014 06:06 AM
jukes4me
Dec 18, 2013 11:10 PM
giandanielxk8
Jan 6, 2013 04:06 PM
