restricted preformance issues
Old Dec 7, 2014 | 12:32 PM
Duffman's Avatar
Default restricted preformance issues
I have a 2002 xj8 which started running rough, I replaced the plugs, cleaned the mas air flow sensor and replaced the vacuum line going to the brake booster. After driving a few miles the restricted performance light comes on and the car starts running rough. I disconnected each coil 1 at a time and noticed a difference in idle so I guessing the coils are ok. Some of the codes that are showing are PO171, PO301,PO304,P0300,P1313. Any info would be greatly appreciated. Thanks
Old Dec 7, 2014 | 12:49 PM
Duffman - I've moved your post from the General Tech Section to the XJ (X308) section where members with the same model can best assist you
regards,
steve
Old Dec 8, 2014 | 06:44 AM
JagV8's Avatar
Misfires are usually coils not plugs. Lean code likely due to misfire.
Check fuel trims to make sure not an actual air leak.
D.K
Dec 10, 2023 02:05 AM
PMKimpton
Aug 3, 2019 08:22 PM
mrplow58
Sep 9, 2015 11:27 AM
kevo
Sep 8, 2015 09:45 AM
XFR_Gold
Sep 2, 2015 12:24 PM
