Road vibrations - less smooth overall ride
Old Feb 24, 2016 | 02:05 PM
Oddman's Avatar
Default Road vibrations - less smooth overall ride
Hi Forum,
Lately I have experienced a slight rougher ride, as in not as smooth as normal. Bumps in road are more noticeable and road vibrations are felt through steering wheel and pedals.
Is this a sign of shock absorbers/dampers needs to be changed or are there other rubber bushings or similar that needs attention?
Any suggestions are very welcome. Thanks a lot in advance.
Sovereign XJ 4.0 1998.
Old Feb 24, 2016 | 02:18 PM
King Charles's Avatar
Tire pressure change would be my 1st check.
Old Feb 24, 2016 | 03:06 PM
Mark SF's Avatar
Well, it could be either. The suspension system as a whole is tuned quite carefully, so any worn component can affect the ride quality.
The best way to proceed is to carefully evaluate all the suspension components for wear. Split and cracking bushings, play in balljoints, leaking / worn dampers, and so on.
On my 2002 XJR with 135K miles, just about everything was done. Bushes, balljoints, shocks, it was all worn out.
Old Feb 24, 2016 | 03:25 PM
Jhartz's Avatar
If it is a sudden change, look for something changing tire balance -- lost weight; winter, ice buildup; pads completely worn. If it has been getting worse over a longer period, the upper shock mounts and ball joints.
Any abnormal tire wear?
Old Feb 24, 2016 | 04:44 PM
kyle04's Avatar
ball joints would be my guess....... had mine done recently and the ride is now, how can i put it, more "exact". I have the sports suspension so the general ride is on the firm side.
Is there any uneven tyre wear (mine were starting to wear on the insides)...?
Old Feb 25, 2016 | 06:41 AM
Oddman's Avatar
Hi,
No abnormal tire wear, and it has happened over time.
Guess I will add ball joints, gaskets and dampers for spring maintenance.
Thanks group for all replies.
Old Feb 28, 2016 | 07:39 PM
Vector's Avatar
You didn't mention how many miles are on the car.
Front upper shock bushings, front and rear sway bar bushing and links.
Changing these on my 76K mile 2001 XJR transformed the ride and only cost about $200 or less in parts. Easy DIY too.
Vector
Old Mar 3, 2016 | 07:25 AM
Highhorse's Avatar
Be sure to check the spindle/hub bearings also.
You'll need to lift the front wheels off the ground a little then grab the bottom of the tire and put your palm on the top and try to rock it. That will give you a possible indication of either the bearing or upper or lower ball joint.
Then do similar at the 3 and 9 o'clock, that will indicate possible tie rod, bad rack or control arm bushings.
giandanielxk8
May 20, 2019 10:23 AM
bongobrown
Feb 27, 2016 08:02 AM
Boeingtravel95
Feb 25, 2016 07:22 AM
Chuck Schexnayder
Feb 24, 2016 12:19 PM
orangeblossom
Feb 23, 2016 01:39 PM
