So I just discovered something horrible...
Old Jun 13, 2014 | 09:02 PM
Lavaman's Avatar
Default So I just discovered something horrible...
Rust! Lots and lots of rust and holes in the floorboard.. I would have never purchased this car if I knew the rust was going to be this bad.. But now that I'm here, I might as well go ahead and fix it.
I plan on welding in some new sheet metal, installing new padding and carpet, then fiberglass for the undercarriage.
Does anyone have any recommendations?
Also, I need help with a few things if you don't mind?
1) Need to know how to get the center console out (to install new carpet)
2) How do I remove the metal panels on the door seal?
Thanks guys! Always appreciated!
Attached Thumbnails So I just discovered something horrible...-34xoutl.jpg   So I just discovered something horrible...-2e5rrsj.jpg   So I just discovered something horrible...-k15gnq.jpg   So I just discovered something horrible...-19s1u9.jpg
Old Jun 14, 2014 | 03:00 AM
Lear45's Avatar
Might want to consider getting a donor car. Once the engine or Transmission fails these cars go for under $1,000. You would end up with a rust free car and a lot of spare parts.
When the engine died on my XJ8, the most I was offered was $300 for the car.
Old Jun 14, 2014 | 05:26 AM
test point's Avatar
The metal panels are held on with super strong double backed tape. Might try heating with a heat gun or even a hair dryer. Some have used dental floss to 'cut' the panel free. I used a razor knife with the blade extended about 3 inches to ease it off. Worked without damage.
Old Jun 14, 2014 | 06:48 AM
jimlombardi's Avatar
Lavaman
Here are the instructions & illustrations on removing the floor console in JTIS manual:
Floor Console PDF file
https://www.dropbox.com/s/1wfg041q31...le%20R%26I.pdf
Floor Console Extension PDF file
https://www.dropbox.com/s/ner6jjyzfv...on%20R%26R.pdf
Floor Console Finish Panel Bracket
https://www.dropbox.com/s/9s8n9y4n45...2076.25.26.pdf
Floor Console Ashtray
https://www.dropbox.com/s/7qrg6urfdt...2076.25.25.pdf
Floor Console Stowage Compartment
https://www.dropbox.com/s/9gqsed107s...2076.25.16.pdf
https://www.dropbox.com/s/b0gsja74j3...el%20R%26I.pdf
Here is the front door weather seal information:
https://www.dropbox.com/s/besyrti8xu...ip%20R%26I.pdf
Jim Lombardi
Old Jun 18, 2014 | 07:07 PM
JaguarXJR02's Avatar
WOW that's some major rot!
how many miles on the car? what part of the country has it spent most of its life?
Old Jun 20, 2014 | 04:57 PM
Lavaman's Avatar
Yeah! It was pretty bad.. About 85% of the rust is now gone, and new sheet metal was welded in.
90,000 miles and it was spent in KY most of its life. Wrecked, totaled, and literally just sat for years.
Old Jun 22, 2014 | 09:39 AM
Niklas Xeronen's Avatar
how much time and money did you spend with this?
Old Jun 22, 2014 | 12:21 PM
props for bringing her back to life! It looks like pacific blue for exterior colour, if that's so you've got a rare and excellent colour!
Old Jun 22, 2014 | 11:41 PM
Lavaman's Avatar
Sheet metal - $50 or so
Spot weld by me - Free
Quicksteel - $150
I began by cutting out the old rust with a saw, then measuring, sawing and bending new sheet metal to fit perfectly over the holes. After that I spot-welded the sheet metal, applied quicksteel to seal it thoroughly, then sprayed the undercarriage with rustoleum, and finally applied bondo/fiberglass to seal the undercarriage.
Old Jun 22, 2014 | 11:43 PM
Lavaman's Avatar
Thanks! Actually it's just a metallic black
It will actually be re-painted next month, so maybe I'll try the pacific blue!
This has been a long and painful journey trying to get her mechanically and aesthetically sound, but I'm almost officially done! Then comes mods
Old Jun 23, 2014 | 11:09 PM
Lavaman's Avatar
So here are a few pictures of the interior so far.
What's new or changed:
-New sheet metal on floorboard.
-New padding.
-New carpet (plush, house carpet)
-Marine vinyl headliner, trim and handles.
-Center console wrapped in two-tone black leather/camel marine vinyl.
-Hand-stitched sun visors camel/black piping. (Getting better at sewing.. lol)
I still have a few additional mod ideas for the interior.. But this is what I've completed so far.
The marine vinyl is some great stuff! And I love driving with no shoes
Attached Thumbnails So I just discovered something horrible...-2h5v2jc.jpg   So I just discovered something horrible...-97012f.jpg   So I just discovered something horrible...-x1a6fr.jpg   So I just discovered something horrible...-2u7xbgk.jpg   So I just discovered something horrible...-2zhjfrk.jpg
So I just discovered something horrible...-288nspx.jpg   So I just discovered something horrible...-2w3z49w.jpg   So I just discovered something horrible...-5pn28k.jpg   So I just discovered something horrible...-25swkmw.jpg   So I just discovered something horrible...-2je4guo.jpg
Old Jun 27, 2014 | 10:02 PM
Lear45's Avatar
Thanks for sharing the great story with pictures. Nice to know you didn't give up. They are great cars once you get them working right. May you get many miles/years enjoyment from it.
PolkNole
Oct 21, 2025 02:22 PM
MrWhite
19
Jun 14, 2022 07:49 PM
mikiep
Dec 20, 2019 07:37 PM
multistrada74
Oct 8, 2015 08:58 AM
hoodun
Oct 6, 2015 08:34 PM
