Spacer size for big brake fitment
Old May 7, 2016 | 08:05 PM
srhodes87's Avatar
Default Spacer size for big brake fitment
I had a set of brembos from a xjr100 for sale, but I decided to put them on my car instead. Everything went OK except that the wheel is not deep enough to fit.
I know that some people have encountered this and so I would like to ask what size spacer they used.
this is what I am looking at right now.
Wheel Hub Centric Adapters 5x120 7 ¦ 5x4 75 Jaguar XJ XK Spacers 1 25" | eBay
Old May 8, 2016 | 09:40 AM
Addicted2boost's Avatar
I don't know the answer to your question but, if you tried getting your wheel on, how far away is the rim hub from the spindle hub? Between 1 & 2 inches??
Old May 8, 2016 | 01:38 PM
SteveM's Avatar
I used 20mm spacers with the Pentas to clear Brembos.
Old May 9, 2016 | 05:46 PM
Highhorse's Avatar
+1, ....1/2" is at least what I'm going to need when I do mine with the Pentas.
Old May 10, 2016 | 03:43 PM
SteveM's Avatar
1/2" (12.7mm) might just barely be enough to clear but will leave very little if any clearance between the spoke and caliper.
Old May 13, 2016 | 01:30 AM
srhodes87's Avatar
I bought 1.25" spacers just to be sure they would fit. They definitely do. I think i could replace them with 20mm one's.
Stance is on point though!
Asteroids on 1.25 in spacers to clear the brembos from a xjr100
Old May 13, 2016 | 05:28 AM
Highhorse's Avatar
Did you just do the front or the back also to square the stance?
Old May 13, 2016 | 10:24 PM
Johnny_B's Avatar
Cool
Can you take a pic from the side, from a couple feet away? I've never seen the Brembo brakes behind asteroid wheels
Old May 14, 2016 | 04:39 AM
srhodes87's Avatar
Will do tomorrow or whenever I get the brakes all on.
For now, there is only one spacer on the front drivers side wheel. I am installing the passenger side brakes tomorrow.
I have to see what is going on in the rear...but yeah i need to even it out. It looks kind of funny as is.
However, it is my commuter. I only go fast straight. For the curvies I use my Acura NSX!
I bought big spacers so that I could be sure the wheel would fit and get it out of the driveway. Likely I will buy smaller ones now that It is mobile and I have a better idea of the proper size.
The spacers were only $69.99 and seem to be pretty solid.
Question:
DO I NEED SPACERS IN THE REAR TO CLEAR THE BIG BRAKES TOO?????
Old May 14, 2016 | 06:04 AM
Highhorse's Avatar
From what Luc told me awhile back, the rears do not need the spacers. But I would want a square stance and would install them because of that.
Here is our conversation a couple years ago and his links to his pics and previous posts on it....https://www.jaguarforums.com/forum/x...wanted-128967/
Old Feb 10, 2017 | 05:32 PM
Benson7's Avatar
hi, could you kindly tell me which spacers did you get ? I have a set of h&r (15mm) on each side and I am having problems...they don't fit because the nuts don't sink into the spacer (lug to long). Did you happen to cut down the stud ?
cheers
Old Feb 10, 2017 | 05:34 PM
Benson7's Avatar
cheers
Bcrary3
Aug 3, 2016 08:23 PM
Sublyminal
May 9, 2016 06:12 PM
uncheel
Apr 19, 2016 10:31 AM
retriever-007
Apr 8, 2016 03:16 PM
haroldleggett
F-Pace (X761) / C-X17
Apr 8, 2016 11:13 AM
