Spark plug boss seals
Old Apr 21, 2018 | 08:31 AM
FinnJag's Avatar
Default Spark plug boss seals
Hi all,
I am struggling to get correct gasket kit for my camshaft cover. In first delivery cover gaskets were wrong and now in the second kit they are OK but spark plug seals are different. I would like to know if it is OK to use o-rings instead of "long" seal where are three o-rings connected together?
Currently there is this longer model in use but I got o-rings within second delivery. O-rings fits perfectly but oil flow gets a minor change if I change them. Is it harmful for something what I do not see now? I think that this has nothing to do with breathers since they are not located nearby. Attached pictures may help to get the idea of what I mean. There are o-rings (black) and original seal (light brown) side by side.
Attached Thumbnails Spark plug boss seals-img_20180421_095243.jpg   Spark plug boss seals-img_20180421_095257.jpg
Old Apr 21, 2018 | 09:50 AM
avern1's Avatar
It would be most helpful to know the engine you are working on. Model, year and engine. I assume from the pictures your XJ8 is a 96,97,98 model 4.0 liter.
You need the 3 ring long set to seal the cam covers. If you leave the center ring out it is possible to get an oil leak around the fastener and then have oil accumulate around the coil plug boots causing a misfire condition. I encountered the O-ring problem when working on my 98 XJ8. I contacted Jagbits where I bought I bought my gasket set and they sent me right away the correct plug seals. The AJ26 engine uses the long 3 ring seal and the later AJ27 is machined differently and uses the 2 O-rings.
Old Apr 21, 2018 | 01:51 PM
FinnJag's Avatar
Good assumption.. it is XJ8 1998 3.2.
There is also a black center ring around the fastener (on place in the first picture) so there should not be any problem with leakages. Just worried if something goes wrong with oil flow.
When ordering the kit I was not able to see engine serial number so first kit which I ordered was for engines up to 981029000. First 6 digit are showing manufacturing date. As said, spark plug seal was correct 3 ring long set but cover gaskets did not fit. Then I ordered a set for engines from 981029001 on. Now cover gaskets are ok but there are 3 individual o-rings. So my engine is some kind of combination.. or is it due to motor size (3.2)? I think it is quite similar with 4.0, just having shorter stroke.
Old Apr 21, 2018 | 03:59 PM
avern1's Avatar
It is the same as the 4.0 Liter but the shorter stroke. Attached is a parts blow up show the part numbers for what you need. The change you see is after 290000 engine number. Your supplier is mistaken it not a problem with the engine.
The correct ones are available and they don't always get matched up with the right kits.
Old Apr 22, 2018 | 02:27 AM
FinnJag's Avatar
Okay. Thanks for the info. I need to send a message to the supplier (British Parts UK) one more time. Jagbits did not have the kit for older engine.
Lagonia
Feb 12, 2022 11:18 PM
dfriedrich208
US Northwest
May 13, 2013 03:00 AM
dfriedrich208
Apr 17, 2013 08:31 PM
Ziggy
Nov 6, 2012 11:57 AM
aviator
Mar 2, 2012 06:13 AM
