Is THIS the speaker I'm supposed to replace for the blinker clicks to sound?
Old Apr 21, 2023 | 07:56 PM
ericnunez's Avatar
Default Is THIS the speaker I'm supposed to replace for the blinker clicks to sound?
I pulled it out of the steering column on the right side, right in front of the ignition switch.
Old Apr 22, 2023 | 05:17 AM
944play's Avatar
That would be the transducer responsible for the in-cabin sound effects, including the blinker tick-tocks (and ignition chimes). Whether it needs replacing can probably be assessed with a AA battery.
Old Apr 22, 2023 | 07:54 AM
motorcarman's Avatar
64 Ohm, 66mm diameter and .5 to .7 watt is what you need to replace it with. (looks like the wires are BROKEN)
Jaguar replacement was EXPENSIVE so I bought 5 from somebody on the internet years ago for $5.00 each.
Old Apr 23, 2023 | 02:26 AM
ericnunez's Avatar
Thanks! I'll see what I can find. Hopefully I'm lucky enough to find some cheap ones.
TexMurphy
Nov 30, 2025 09:34 AM
Knighting
Oct 31, 2019 06:00 AM
AlbBolivar
Jan 9, 2015 07:41 PM
Spikepaga
Sep 16, 2014 07:33 PM
jaginblack
Nov 9, 2010 06:36 PM
