speaker replacement - suggestions?
Old Jan 3, 2021 | 05:33 PM
jeff xj8's Avatar
Default speaker replacement - suggestions?
Hello Jaguar Enthusiasts,
I'm replacing all of them, LNC4140AA (Phillips) is pictured. Shopping around I see Harmon Kardin and Alpine speakers with different letter suffix letters on the part numbers. Are they interchangeable? Which is better?
Are used ones from 20 year old cars? I'd prefer new but I'm pretty cheap. The new don't seem much more expensive than the old but they may be lower quality.?
Any suggestions?
I just got a new Footloose cassette from Goodwill for 49 cents! I need some proper speakers.
Jeffxj8
Old Jan 3, 2021 | 05:51 PM
Highhorse's Avatar
These are $24 a set cheaper than when I got mine 6 yrs ago... https://www.crutchfield.com/p_575R16...te-R165-S.html
...and harness connectors... https://www.crutchfield.com/p_120710...Harnesses.html
These came free with my order, not sure if that still applies... https://www.crutchfield.com/p_142SAC...-Brackets.html
...and if you decide to go with a 3rd party head unit, single DIN... https://www.jaguarforums.com/forum/x...-piece-165345/
Almost forgot to mention, King Charles has the same setup ironically.
Old Jan 3, 2021 | 07:22 PM
jeff xj8's Avatar
Thanks for the suggestions and links Highhorse,
I'm keeping the original, pictured, radio head. I love those cassettes.
Will the Crutchfields mount w/o too much trouble? Did your original grills fit? Did you install the new tweeters into your car? Much surgery?
Great brand name and price looks good. They are currently out of stock.
(I'm replacing a broken door cable and replacing speakers while I have the panel off)
Jeffxj8
Old Jan 3, 2021 | 07:35 PM
Highhorse's Avatar
You don't have to do anything with the grills, leave the originals and I didn't install the tweeters, left the originals, mine were good. The interface plates are super simple and the speakers drop right in. Its about a 20 minute job per door, most of it applying the new connectors and removal/install of the door cards.
Crutchfield is extremely friendly and more than customer helpful. Whether you call them directly or chat online, they can make recommendations for other speakers if you want them to and don't wish to wait for restock, so don't be afraid to contact them...awesome folks.
Old Jan 3, 2021 | 07:41 PM
Addicted2boost's Avatar
Go to your local flea market or eBay has these and they’re accepting offers.
Old Jan 4, 2021 | 03:54 AM
King Charles's Avatar
I run Rockford Fosgate P165 6.5" in mine.
Old Jan 4, 2021 | 12:31 PM
jeff xj8's Avatar
Rockford Fosgate R1675X2
Prime Series 6-3/4" 2-way car speakers
I ordered two pair of these from Crutchfield. The sales guy,(very nice) assures me that 6 3/4 will fit, front and rear, just like 6 1/2. Ill have to do some soldering. 50 USD each pair, free shipping in about two days.
I'm a little skeptical about the fit but we'll see
Thanks for the info.
jeffx308
Old Jan 15, 2021 | 08:08 PM
Col. Sandurz's Avatar
Here is a comparison of stock speakers from a 2001 VDP SC compared to new top of line or higher end (2 years ago) Alpine 6.5 components.
I put them in with R tweeters, stock everything else and sound was better. Worth all the time and energy? not sure. I may still have them in my basement.....
Old Jan 18, 2021 | 08:42 PM
Amphicar770's Avatar
I just replaced my door speakers with a set of Alpine SPR-60s that I picked up a couple years ago. Perfyfit replacement, no retainer or bracket needed. I snipped the wires and used crimp connectors although would have used adapters if I had then handy.
Old Jan 27, 2021 | 02:14 PM
jeff xj8's Avatar
I got the Crutchfield 6 and 3 /4 installed and they sound fantastic. I'm rocking in the free world. I drilled new mounting holes and screwed them to the door panel with the same screws. The leads, provided by Crutchfield , fit perfectly, no soldering. Thanks for the help.
BUT. replacing the door latch cable was, and still is a disaster. (will discuss on another thread. )
jeffxj8
Old Feb 1, 2021 | 02:59 PM
anduha's Avatar
I used Focal Access components in mine, 6 1/2" woofers and fit perfectly, no mods except some minor wiring. Best car speakers I ever had. While you have the door cards off consider adding some Dynamat for better sound deadening and acoustics.
Duke85
May 14, 2020 04:05 PM
Hedman
May 12, 2020 09:48 PM
Red
Feb 3, 2017 09:53 PM
Tsatalia
Jun 30, 2012 10:27 PM
