Sunroof won’t work with drip panel installed
Old Mar 27, 2021 | 06:19 AM
hnatten's Avatar
Default Sunroof won’t work with drip panel installed
Sunroof issue again....
Removed the whole sunroof assembly, cleaned, lubed, checked everything. Reinstalled without drip panel and worked fine.
But when I attach the rear drip panel it won’t work. The panel will tilt but will not go rearward. The panel will drop a bit but then it will get stuck. It seems as the drip panel doesn’t allow the main panel to drop down enough.
Anyone experienced this?
Old Mar 27, 2021 | 04:29 PM
hnatten's Avatar
Solved it. Main panel was sitting too low. Noticed that the washers for the 6 screws was bent from too much torque, this caused the panel to slip down when the screws were tightened.
Replaced washers and it all works now
Old Mar 27, 2021 | 06:43 PM
King Charles's Avatar
Yeah that set-up's touchy for sure.
jagskiguy
Oct 19, 2020 08:14 PM
jag82xj6
Oct 3, 2020 04:24 AM
E-Swift
Nov 12, 2014 08:22 PM
Noah
May 28, 2014 03:21 PM
caldercay
Oct 24, 2011 10:47 PM
