Supercharger oil change - pics
Old Sep 4, 2011 | 12:11 PM
Vector's Avatar
Default Supercharger oil change - pics
I changed to oil in my supercharger today. Not difficult, but I did have to make a special sized tubing attached to a 2 oz syringe to get into the fill hole and suck out the old oil.
I stepped the tubing down from 1/4" or so to about 1/8" using heat shrink tubing. Anything bigger than that wouldn't get far enough into the hole to be able to remove the old oil. It is about the same outside diameter as the red tube on a can of WD-40.
THIS IS IMPORTANT: You also have to stick the tube in the fill hole at a downward angle. If you try to put it straight in, it hits something and you won't get be able to get all of the oil out of the supercharger. Folks who say they could only get 2 oz or so of oil out are using too big a tube and sticking it straight in. (I know, don't go there! LOL)
I was able to get 7 oz. of old oil out of the supercharger and it was the color of very, very dark coffee. My car just turned 60K miles.
I used almost two 4 oz bottles of GM supercharger oil from my local Chevy dealer, $10.89 a bottle plus tax.
When you do it, pack the area below the fill hole with paper towels to catch the overflow when you fill. A flex drive for the 3/16" hex bit would have been nice to have too because it is very close quarters when the fill hole drain plug is being removed and installed.
Pics of the old oil, GM oil and my "oil extraction tool" below.
Old Sep 4, 2011 | 12:30 PM
sparkenzap's Avatar
Thanks for the write-up.
Old Sep 4, 2011 | 04:49 PM
Sean B's Avatar
sealed for life eh?
Old Sep 4, 2011 | 11:29 PM
plums's Avatar
WD-40 straw, syringe, paper towel packing, dark coffee?
Sounds real familiar:
https://www.jaguarforums.com/forum/x...e-notes-57136/
Old Sep 5, 2011 | 03:26 AM
Cadillac's Avatar
Good job, thanks for your thread
Old Sep 5, 2011 | 08:04 AM
Vector's Avatar
Oh no, Plums, you got me! I read that thread before I did mine. LOL.
I do think I added some good info though......photos, prices, flex drive, proper insertion, ect.
Old Sep 5, 2011 | 06:27 PM
plums's Avatar
Must have been a subliminal moment.
The flex drive might not be the way to go. What is needed is the ball end version of the hex key. It's the same principle as a wobble extension in that it allows insertion into the hex at an angle.
Old Jan 21, 2012 | 10:23 PM
03Xtype's Avatar
I have used mobile jet II oil for the superchargers on my AMG mercedes. I think the same company makes the jag superchargers also. How come you used GM oil? Is there a way to find out what the factory would use?
Old Jan 22, 2012 | 08:09 AM
Sean B's Avatar
Jaguar use Eaton's formula and at £30 a bottle x2, on back order everywhere, from a German supplier, no wonder the GM stuff is used. It's the same stuff, just 2/3rd's cheaper.
Old Jan 22, 2012 | 12:59 PM
plums's Avatar
In addition, the GM superchargers are Eaton superchargers. Both the M90 and M112.
It's an open "secret" on all of the Mustang boards. The GM oil is even cheaper than the Ford oil, which is also often on backorder.
Walk in to any GM dealer, ask for it and the parts guy won't even need to lookup the part number.
Don't know why everyone says it smells bad though.
@Sean ... how about 3 GBP
Old Jan 5, 2013 | 03:50 AM
H20boy's Avatar
Thanks to this thread, i was able to get another 1.8 oz of fluid using the wd-40 straw and a smaller syringe I had lying around. The 1/4 diameter tube did the first 4.5 oz, but couldn't go to the 'left' of whatever obstruction was directly in front of the fill hole. The straw did, and found another sump area over there containing fluid.
Attached Thumbnails Supercharger oil change - pics-p1365222492-4.jpg   Supercharger oil change - pics-p1365224052-4.jpg   Supercharger oil change - pics-p1365222482-3.jpg
Last edited by H20boy; Jan 5, 2013 at 04:34 AM. Reason: youtube link wasn't working at first
Old Jan 6, 2013 | 06:02 PM
Red October's Avatar
Originally Posted by Sean B
sealed for life eh?
Nothing is sealed for life if you have a drill or a big hammer
Old Jan 7, 2013 | 10:02 AM
Sean B's Avatar
If you know why I mentioned that, you'd understand where I'm coming from, I rebuild them, and not with big hammers
Old Feb 19, 2013 | 10:21 PM
Robert Page's Avatar
Hitting this job in the next week. I noticed in Jaguar world magazine that a company in the UK is doing a complete service kit for this in syringe and pipe work. Thanks for all the info guys.
Old Mar 31, 2013 | 08:21 AM
amcdonal86's Avatar
Does anyone have any idea if this procedure is possible to do on the AJV8 supercharger? I have an '07 XKR and I think I'm having some supercharger noises that I want to try to solve by changing the fluid.
Old Mar 31, 2013 | 09:17 AM
plums's Avatar
Same supercharger ... updated generation.
But, if it's a rattling noise ... that would be the coupler ... check ebay for replacement kits.
Old Mar 31, 2013 | 09:19 AM
plums's Avatar
Originally Posted by H20boy
///but couldn't go to the 'left' of whatever obstruction was directly in front of the fill hole. The straw did, and found another sump area over there containing fluid.
That would be one of the drive gears or possibly the coupler.
Old Apr 1, 2013 | 12:40 PM
amcdonal86's Avatar
What do you think this noise is?
I know there is powersteering noise, but I think the whirring sound is different.
ZJag
26
Sep 5, 2016 03:33 PM
user 652867429824
Sep 5, 2015 12:53 PM
gregster41
General Tech Help
Sep 4, 2015 03:51 PM
pnwrs2000
Sep 3, 2015 11:55 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
