torque specs for the output shaft assy on differential...
Old Nov 8, 2015 | 07:16 AM
times2fxp's Avatar
Default torque specs for the output shaft assy on differential...
I am changing the REAR DIFFERENTIAL OUTPUT SHAFT
and its actually quite easy. Mine sounded like rocks rolling around, But I need to know how tight I should get the assembly. I enclosed a picture so one can see what I am talking of.
I have alldata but they dont show much on that part, let alone anything on that differential.
Attached Thumbnails torque specs for the output shaft assy on differential...-s-l1600.jpg
Old Nov 8, 2015 | 08:00 AM
motorcarman's Avatar
Why did you remove the entire assy?????????????????
That threaded part sets the crown wheel to the pinion laterally.
To renew the bearing, you just remove the snap ring, slide it out and replace the stub axle/bearing. Renew the outer 'O'ring, then make sure the shims are still in place.
Put the snap ring back and you are done.
You need to put the threaded aluminum collar back 'WHERE IT WAS'!!!!!!!!!!!!!!!!!!!!!
Did you mark it??????
bob gauff
Old Nov 8, 2015 | 08:39 AM
avern1's Avatar
I have attached the torque spec's for the rear end. Let me know If you need it i may be able to email you the repair sections for the differential
File Type: doc
Old Nov 9, 2015 | 02:47 PM
times2fxp's Avatar
Thanks!
For the other guy, bearing froze and spun in the collar hence changing the whole thing. Been a mechanic for 37 years now. Think I have a slight grasp on things.
And sure, anything you have on that rearend would be great. Nothing in alldata or Mitchell about it
Old Nov 10, 2015 | 12:21 PM
avern1's Avatar
send me an email at avern1@yahoo.com and i can send the manual
Old Nov 11, 2015 | 05:13 PM
times2fxp's Avatar
email sent
Old Nov 13, 2015 | 07:53 AM
Marcel de Vries's Avatar
Hi Vern ,
i just sent you an email request for the manual also
I hope you can share it
Thank you!
julesjag1
41
Feb 28, 2016 04:48 PM
BlkCat
Nov 6, 2015 05:03 PM
xjsman89
Nov 2, 2015 02:35 PM
Edwin12020
Nov 2, 2015 01:30 PM
fingers
Nov 1, 2015 08:52 PM
