Trans Fault and Check Engine lights are now on?
Old Apr 12, 2023 | 11:50 AM
Johnnywrench's Avatar
Cool Trans Fault and Check Engine lights are now on?
Good afternoon everyone , the car sat in the garage for about 3 months went out yesterday for a ride and when i stop at parts store everything was fine. Got back in to go home and car would not move in reverse unless I gave it gas. Then went to go forward and slipped a lot. Got in the road and it seems like it is stuck in second gear.got car home Tried reset and check engine light on and trans fault comes right back on . Feels like stuck in gear. In neutral car wants to go forward,reverse have to hit gas and drive is very sluggish. No leaks and car has been service regularly. Ant ideas? Thanks in advance. Car is 1997 XK8 vin # SAJGX2749VC017644. milage is 148000.
Old Apr 12, 2023 | 12:29 PM
Quadcammer's Avatar
fluid level?
Old Apr 12, 2023 | 12:42 PM
Fluid level is good ,no signs of leak?
Old Apr 12, 2023 | 12:55 PM
Quadcammer's Avatar
did you actual check the level or do you just think its fine because there are no leaks?
In any case, there are a few key issues with those transmissions, so perhaps a search would help you out.
Old Apr 12, 2023 | 02:07 PM
motorcarman's Avatar
WRONG FORUM but the ZF 5HP24 is the same in the X308 sedan.
The LIMP HOME default is 4th GEAR.
Probably the forward drum. ('A' drum)
Common problem with the 5HP24 in Jaguar and BMW cars.
Old Apr 13, 2023 | 11:10 AM
Sorry for delay in posting results of fluid level check. I was putting together my other Cat a 1971 Mercury Cougar XR7 convertible. Just got the fill plug out and fluid level is good a little stream of fluid from fill plug. It is a little dirty but does not smell burnt. Trans was serviced about 20 to 25 thousand mile ago in 2017. Thanks for any help .
Old Apr 13, 2023 | 02:57 PM
RJ237's Avatar
Did you remove the plug with engine running and transmission temp. 30-50 deg C?
Old Apr 13, 2023 | 08:13 PM
Peter_of_Australia's Avatar
Hi Johnny,
I wanted to ask the exact same thing as RJ235: Did you have the car level, the engine running and the ATF temperature around 40°C?
Other than that: If this were a ZF 6hp26 transmission, I would also mention that it could be the 4 tubes and the seal bridge needing to be replaced, which you all find after removing the fluid-pan and then removing the valve body. But I am not sure, of you find the same in a ZF 5hp24, as I did not have to do that yet on my X308. But I did it on the S-Type.
And another idea, which I can only hope makes sense, as I did not fiddle around with that on the X308, but on my X-Type: Thus, hoping that it is the same on the X308: Your failure description made me think that the actual cable connection between your J-Gate and where it ends at the transmission is loose (more likely at the transmission end). I.e. mechanical problem, easily solved... So if you "command" the transmission to be in a certain gear via the J-Gate, but the "command" gets distorted or lost "in translation" the transmission would do something else...
Old Apr 14, 2023 | 06:44 AM
Thanks for the areas to look at. I will check the connections today and let you know. Also after car sat for 2 days I got in and car went into reverse fine put it in Drive and slipped a bit then drove fine. Went down the road and Trans fault came back on with engine light. Car is now in garage. Will let you know about electrical connection later today. Thanks again for replying to me. Car was level and warmed up when I checked the fluid.
Old Apr 14, 2023 | 08:44 AM
WARMED UP will not give an accurate fill level. (above 50 C or 126 F)
I start with DEAD COLD in the morning to get a correct level as 30 C comes up fast while working under the car.
I never let it get above 40 C because 50 C is MINIMUM and I don't like minimum.
pcravens
Jan 1, 2020 11:32 AM
rsims
Oct 2, 2016 08:18 AM
Loxmth
May 3, 2015 11:52 AM
Beanie1941
Jun 11, 2013 05:57 AM
abnas2
Oct 10, 2012 05:20 AM
