Transmission fault light
I have a 1999 vanden plans and only yesterday it ran good but all of a sudden in drive it revved up without going forward and the lurched forward again and again. Reverse is fine. Then a transmission fault light came on. Now today the light is out but in gear it still revs like it is in neutral and then catches and lurches forward. My OBD has no fault codes. Any ideas?
Received 2,609 Likes
Don B (05-14-2019)
Don B (05-14-2019)
I expect Bob has it right, as usual. It's probably A drum failure. Use the search function or google for instructions on checking fluid level in the ZF 5HP24. It's not fun. If the fluid level is good, it's likely the A drum. Do not take it to a dealer if you don't plan on repairing it yourself, find a transmission shop familiar with the ZF, which is used in many BMW's and other foreign cars..
Arsalan Ulhaq
05-09-2019 09:12 AM
alephzain
16
03-01-2019 06:00 PM
innzane
04-03-2016 08:43 PM
steffenvh
01-10-2010 11:45 PM
