Transmission issue
Old Mar 12, 2021 | 07:55 AM
ncanales33's Avatar
Default Transmission issue
Hello everyone, for some reason my XJR is having issues at first start. In cold weather or if I dont leave it running for at least 5 minutes it acts up. It will give me a Transmission Failure on the dash and won't shift out of first. If left running for a while it will run and drive fine. When it acts up and I put it in drive it gives a jerk.
Old Mar 12, 2021 | 08:24 AM
motorcarman's Avatar
What DTC (if any) is stored in the TCM?
Old Mar 12, 2021 | 10:06 AM
xalty's Avatar
check fluid level
bad 13 pin connector sleeve can also cause a bunch of weird issues
Old Mar 12, 2021 | 11:36 AM
The W5A580, 722.6 or NAG1 have the problem xalty mentioned.
I gave a copy of the Jaguar TSB to a customer that also had a Chrysler 300 with a leaking gearbox.
The gearbox leak turned out to be exactly that.
File Type: pdf
BLACK52TD
Sep 6, 2018 04:18 AM
okXJR
Mar 31, 2015 06:28 PM
strokez
Mar 11, 2014 01:16 AM
rocket
Mar 26, 2013 11:17 AM
plush
Jul 25, 2011 10:17 PM
