Trouble codes P0327,P1646, P0333 ?
Old Jul 15, 2016 | 02:01 PM
peeterak's Avatar
Default Trouble codes P0327,P1646, P0333 ?
Hi everyone! I`m new Jag owner XJ8 4,0 MY2001. On first day everything was ok but next morning starts with problems. I start the car, engine starts and dead next second. Battery was dead. I but on charger, car starts but some of cylinders don`t work. Restricted performance appear in the dashboard. I drive somehow to work. When i stop,then car has no power to take off. I replace battery, clear all trouble codes and car seems working normally. Drive 2-3 km. and same ting happened. No power gas pedal-no respons. I left car to parking place and come back later. Car starts and i drive back to workplace where i have diagnostic tool. Engine works but transmissoin was little strange. I made diagnostic and there was trouble codes:
P0327 -static-Knock sensor 1 (bank 1) control circuit (-)
P1646-static-Uncnown fault
P0327-sporadic-Knock sensor 1 (bank 1) control circuit (-)
P0333-sporadic-Knock sensor 2 (bank 2) Signal too large
P1000-sporadic- Unknown fault
P1646-sporadic- Unknown fault
P1647-sporadic- Unknown fault
Please give me advice what to check? Knock sensors?
Sorry my english, its not my home language
Old Jul 16, 2016 | 02:20 AM
Col. Sandurz's Avatar
Its late here but I remember some of those codes when I had a bad MAF.
Try unplugging the MAF and see if car runs.
maybe that helps
Old Jul 16, 2016 | 05:22 AM
peeterak's Avatar
Today I check knock sensors. Bank 1 sensor connector was fill with coolant liquid. I clean this and now engine works normal. But one trouble code P1000 is still active and restrict perfomance is still on.
Old Jul 16, 2016 | 07:08 AM
RJ237's Avatar
P1000 is not a trouble code. It shows that the ECU has not completed emission tests and will change to P1111 when tests are complete.
You may need to drive the car to get the restricted performance to clear, but that may still be displayed if there are Jaguar specific codes in the B or C series that you can't display with a generic code reader.
Old Jul 16, 2016 | 09:43 AM
peeterak's Avatar
Thanks for answers. But how I can get off this restricted performans? This is all the time in dash and thats very annoyng.
Old Jul 16, 2016 | 11:18 AM
RJ237's Avatar
Try a hard reset. Disconnect negative battery cable and touch to positive post for a few seconds. Engine will start at higher revs initially and shifting may be rough at first.
Old Jul 18, 2016 | 12:18 AM
JagV8's Avatar
Any codes apart from P1000?
Look them up in the codes PDF /JTIS - free download.
Old Jul 18, 2016 | 05:27 AM
Addicted2boost's Avatar
Did you get this issue situated?
Old Jul 18, 2016 | 01:10 PM
peeterak's Avatar
Today I made hard reset, but restricted perfomance still on. I must check trouble codes again...
Blue_XJ8
Apr 10, 2016 06:25 PM
drdan7
Mar 30, 2016 08:24 AM
gene61jag
Mar 28, 2016 05:45 PM
oldish git
Mar 28, 2016 09:58 AM
