urgent! please power steering fluid overflow
Old Jan 26, 2014 | 07:56 PM
vincent661983's Avatar
Default urgent! please power steering fluid overflow
I have posted a thread about the whining noise coming for the engine bay.
today i discovered all my power steering fluid was all gone and spilled out from the cap valve?and the hot engine burnt out the fluid in smoke
i refilled the fluid and it was keep leaking from the cap valve later,
i opened the reservoir and i saw the fluid had so much bubbles turning like foam?
note, i live in NY and has been very cold recently
please please help for any advise
Old Jan 26, 2014 | 10:12 PM
avt007's Avatar
I recently replaced the pump in my XJ8. I had one heck of a time trying to get all the air out, in fact, it was a huge pain.
I got the best results by having both front wheels off the ground, and manually turning it lock to lock, countless times.
The air just doesn't like to come out. You can see the bubbles come up into the reservoir, but a lot of them get sucked back in when it's running.
All I can suggest is patience, and lots of fluid to hand. Mine overflowed badly a few times.
Old Jan 27, 2014 | 04:04 PM
update status,I ended replacing the steering pump , paid 2 hours of labor at the shop plus the price of the part
occh, too much issue of X308, perhaps due to the age of the vehicle. X308/Jaguar at that era still had too much issues on their car quality,lets agree with that . thou I love this car but too much headache
I still have a list of things to be fixed
Old Jan 27, 2014 | 06:46 PM
Vector's Avatar
Actually, the quality of XJR's of this era, other than known faults like the timing chain tensioners, is regarded as exceptionally good. They have better transmissions than the XJ8 and no variable valve timing or electronic suspension components (before the 2002 model.)
You are driving a 14 year old luxury performance sedan, which was expensive to buy when new and expensive to service then and now when major things go wrong. That is why we see a lot of these cars passed on to the third or fourth owner with major problems that have to be fixed. The previous owners either did not do proper maintenance, which any car needs, or sold them when they were told what the repairs would cost.
A good 308 XJR is about as bullet proof a 370-400 HP sedan as you are going to get, properly maintained, of course.
Vector
Old Mar 10, 2014 | 02:32 PM
ok, to give you guys a update, the new PS pump is making the same noise as the original leaking one thou it works fine .
the noise drives me nuts, and I am taking my car to the shop
nightmare one after another
Old Mar 10, 2014 | 03:56 PM
plums's Avatar
is this not the vehicle that was submerged up past the wheel hubs a few months ago?
in that case, both the steering rack and the pump would have been submerged in water.
Old Mar 10, 2014 | 05:07 PM
I dont think it was my car submeged in water
ok, the mechanic just called me, they changed another PS pump, same noise, they are going to check the belt tomorrow
Old Mar 12, 2014 | 09:53 AM
in addition, I could tell the car is making that noise before I fire up the engine but just turning the key to the ACC position. any ideas what is wrong and the source of the noise.
I will check the pulleys and pulley alignment this weekend
Old Mar 12, 2014 | 10:17 AM
Jhartz's Avatar
On my Range Rover, it was normal and part of the supercharger. Always heard as a soft whine on ACC key position.
But not familiar with XJR superchargers. Might be the throttle body . . . ?
Old Mar 12, 2014 | 10:42 AM
Mikey's Avatar
The pump is making noise without the engine running?
Old Mar 12, 2014 | 11:07 AM
no, Mikey
the mechanic changed another pump but same noise, so It is not the pump issue now.
Dicque
Sep 19, 2015 12:53 PM
sogood
Sep 15, 2015 07:35 AM
1964Daimler
Sep 9, 2015 11:28 AM
MrMellor
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
