VVT sprocket installation
Old Aug 20, 2016 | 04:39 PM
Big Dizzle's Avatar
Default VVT sprocket installation
I'm putting back together my 1999 XJ8 after replacing the timing chains and tensioners and I'm wondering if I need to hold the VVT toward one side or the other as I torque down the bolt securing it to the camshaft. In the 308 workshop manual there is no mention of positioning the VVT as it is tightened. I have a special tool that came in the timing lockdown kit that has two little pins that would allow me to position the inside of the VVT mechanism as I tighten down the sprocket, but again there is no mention of this tool in the workshop manual.
Thank you!
Old Aug 20, 2016 | 09:23 PM
harvest14's Avatar
I believe you hold the sprocket fully counter clock-wise (retarded position), if I remember correctly. I did it about a year ago, but I really think that's what I did.
I feel certain that info is in one of the timing chain threads on here. That's probably where I got the info in the first place. I think some folks claim it's not necessary to hold it in position, but the directions I followed included that step.
Here is a fairly recent thread that addresses the question:
https://www.jaguarforums.com/forum/x...on-s-c-158869/
Old Aug 21, 2016 | 05:23 PM
Big Dizzle's Avatar
Default Broken Bolt
While torquing the passenger side intake camshaft sprocket holding bolt it cracked at around 100 Nm of torque never reaching the recommended ~120 Nm. I was able to remove the bolt in one piece, but it has a spiral fracture between the threads. This is the bolt that is bored through the center for returning the oil from the VVT. Does anyone know where I can get a replacement?
Thanks!
Old Aug 21, 2016 | 05:39 PM
harvest14's Avatar
Is that the bolt that goes through the VVT sprocket? Is your VIN ending in 853935 or lower? Is it about 63mm long?
If all of the above is "yes", then I think the following is the bolt. Obviously you would need to investigate more thoroughly before purchasing.
Terrys Jaguar Parts: Search Results
Old Aug 21, 2016 | 07:22 PM
Big Dizzle's Avatar
My VIN is a little higher, my bolt is shorter (about 50 mm), and yes it is the one going through the VVT sprocket.
Thanks.
Old Aug 21, 2016 | 07:30 PM
harvest14's Avatar
This is the only other one I see... (38 mm)
You could call them in the morning with your vehicle information and perhaps they could confirm which bolt you need for your car. I know several of the Jaguar forums sponsors will do that for you.
Old Aug 23, 2016 | 04:42 PM
Big Dizzle's Avatar
That looks like it could be it, if it has a hole through the center. 50mm is the overall length of the one I have.
Thanks!
Old Aug 23, 2016 | 05:21 PM
BobRoy's Avatar
I believe I have the one you need. Just took it off one of my old cams. From the base to the end of the threads it's ~38mm. Total lenght is about 48 mm. PM me your addrest and I will send it to you.
euphonium01
Mar 4, 2022 02:04 PM
Apr 3, 2018 11:48 PM
byjosh
Apr 1, 2016 02:11 PM
Feb 19, 2008 06:58 PM
Apr 2, 2007 11:08 PM
