What can you put in your trunk
Old Aug 26, 2012 | 02:57 PM
mechelement's Avatar
Default What can you put in your trunk
without the carpeted panel sinking into its housing? Thus far, air is the only thing that won't sink the panel. The overall design seems poor.
Can a full size spare fit in there? Will it prevent the panel from caving in?
Old Aug 26, 2012 | 03:40 PM
Boomer from Boston's Avatar
You could always cut out a piece of plywood to sit on top of the panel, and spread any loads.
Old Aug 26, 2012 | 07:24 PM
JaguarXJR02's Avatar
they expected a 1/8 inch long carpet shelf would keep the panel level, they were wrong haha. I use a bunch of blankets to keep the shelving level, it didn't even collapse with 750lbs in the trunk
Old Aug 26, 2012 | 08:10 PM
Is that what you did? Did you cut it to fit the entire trunk area?
Did you set them underneath the panel?
Old Aug 26, 2012 | 11:18 PM
Evvster's Avatar
Default leave the spare in
The 2 foam rectangles on the underside of the panel are indeed meant to rest in the spare. I only experience caving when it isn't present (which is rare!) Fill the area under with something as tall as a full spare and you should be golden.
Old Aug 27, 2012 | 07:22 AM
Will a full size spare fit under the panel and keep it flush with the rest of the trunk?
Old Aug 27, 2012 | 10:58 AM
Roger77's Avatar
I have a full size spare and the panel still sags
Old Aug 27, 2012 | 11:51 AM
yes, trunk looks completely stock, and you end up with a stash of blankets for emergencies/transporting objects in the back seat
Old Aug 27, 2012 | 12:22 PM
Damn. So full size spare and a shim would do the trick.
Old Aug 28, 2012 | 10:00 AM
SuperSport's Avatar
That's strange, I never knew it, but I guess mine was modified before I got it. I've got a carpet covered piece of 1/2" plywood in mine. Never had any trouble...
dsnyder586
Dec 29, 2024 07:39 PM
mbergen
Oct 23, 2019 10:26 PM
smith356
Oct 7, 2015 06:41 PM
al_roethlisberger
Sep 9, 2015 09:14 PM
prettydaim
Sep 7, 2015 05:16 PM
