What did you do to your X308 Today?
Old Feb 9, 2026 | 01:28 PM
  #5601
Hooli's Avatar
Originally Posted by Vauxi
Big main bearings are basically not replaceable items. They are placed inside the housing casting. But snout bearings and rear bearings are cheap to buy.
4.2 sc swap needs only intake elbow seal from 4.2 because that is different. This is what I recall of reading.
Cheers, I'll investigate more when it's warm enough to take it apart.
Old Feb 25, 2026 | 07:38 PM
  #5602
Philip_A's Avatar
Started the car up, drove a while and ended up idling ten minutes. Check engine light
What the code? Oh great. Upstream O2 sensor. Great. I need to check the heater on that. Might be fouled or burned out.
That would explain the lumpy idle until it's warmed up.
Phil
Old Feb 26, 2026 | 07:34 AM
  #5603
RandyS's Avatar
The Duchess had that problem, and we acquired one. We had a shop install it
due to having no lift to be able to get to it adequately, We have seen other members
who were able to accomplish the task themselves.
Old Feb 26, 2026 | 07:57 AM
  #5604
Philip_A's Avatar
I'm considering pulling the engine again anyway to put it on the bench and solve the oil leaks. The valve seals have leakdown also but that's not too much of a worry. It's also developed a noisy lifter which is more concerning.
I'm still not 100% convinced I've got a slightly weepy head gasket; it's not using coolant so it's hard to tell. I might stump up for a test kit to see if there's combustion gases in the coolant.
I'll eventually replace the front suspension and then get back to enjoying driving the car.
It's been a hectic few months, here.
Phil
Old Feb 26, 2026 | 09:09 AM
  #5605
Hooli's Avatar
I've been ignoring clunks but got to the point I think I need to book mine in for Vee mounts & a front suspension refresh once it gets slightly warmer over here. It's really starting to annoy me & feel a little vague at times on the road, I know the RH Vee mount doesn't look healthy.
Old Feb 26, 2026 | 01:09 PM
  #5606
Philip_A's Avatar
Any recommendations on brands to use/avoid for oxygen sensors?
Old Feb 26, 2026 | 06:52 PM
  #5607
Philip_A's Avatar
Went put fuel. Gave it a run at 70 in 3rd for about 5 miles.
Guessing the sensor was grumpy. It's probably borderline bad, but until it starts triggering again I think I'll pretend it didn't happen.
Went undo the shock top nut to pack the top mount with washers to shut it up banging and the little nub on the top sheared off. Great. That'll be meeting Mr Angle Grinder when I get new shocks, then.
Phil
Phil
Old Feb 28, 2026 | 05:17 PM
  #5608
Philip_A's Avatar
...no, it's totally borderline. Randomly the same code comes back.
Phil
Old Mar 3, 2026 | 09:46 AM
  #5609
basilseal's Avatar
I'm learning these cars are proverbially English in a great many ways... including inspiring in drivers a polite fiction, much like the patriarch of an attractive and well-bred family, that EVERYTHING is FINE and it's much the most polite thing to ignore the ominous signs that something is amiss under the hood.
Old Mar 3, 2026 | 01:30 PM
  #5610
RandyS's Avatar
English electrical engineering, while adequate in theory, often translated to
sub-par on practice. To be fair, the bean counters more than likely exerted
influence over the approval process such that a 15 year life was deemed (generous assumption)
adequate, and we are almost 15 years beyond that expectation. Plastic
housings, solder points under stress, and natural oxidation of electrical
junction points all begin to cause distress.
Old Mar 16, 2026 | 07:51 PM
  #5611
Philip_A's Avatar
Replaced the A bank upper oxygen sensor. Took a large breaker bar to undo, typically. Check engine light begone, fuel economy improved.
Phil
Old Mar 17, 2026 | 05:37 AM
  #5612
Hooli's Avatar
I had one of those done when I got my car as it kept giving a code. I'm very tempted to get the other three as well to see if it cures the poor MPG it's always had.
Old Mar 17, 2026 | 06:42 AM
  #5613
Philip_A's Avatar
The two that would affect that are the upper pair. Plenty of other factors, collapsing catalytic converters, blocked mufflers, vacuum leaks, faulty iac and ect sensors also.
Phil
Old Mar 17, 2026 | 04:19 PM
  #5614
Hooli's Avatar
Phil
I'll have to have a look at the fuel trims, I think they are pretty similar last time I did.
It seems to run fine, has loads of power blah blah blah so it's annoying.
Old Mar 17, 2026 | 05:31 PM
  #5615
Philip_A's Avatar
Replaced the front shocks, upper mounts and bump stops this afternoon after work.
Much nicer now to drive.
Phil
Old Mar 18, 2026 | 04:55 PM
  #5616
Philip_A's Avatar
130,000 miles!
Also, fixed the clock console, the trim clip holes had broken last time I had to take it apart.
Glued the broken boots back on and augmented with some Veroboard.
Good enough.
Phil
Old Mar 31, 2026 | 12:26 PM
  #5617
Philip_A's Avatar
I put a cup in the cup holder yesterday; accelerated and it broke the cup holder through the sheer G forces produced by such a machine.
I glued the broken pieces (stupid design) back together and now it works again.
Also took it completely apart and cleaned it. Yuk. Previous owner liked lattes.
Phil
Old Apr 1, 2026 | 05:09 AM
  #5618
eliotb's Avatar
I've twice launched cups of coffee into the back seat with the acceleration from a downshift. It is a stupid design. Absent buying one of these plastic or rubber "between the seat and console" things you see on TV, I now use a Yeti 20oz cup with a textured exterior pushed between the passenger seat and the console. I replaced a console top and cup holder on an x350 I had years ago and there sure were better ways to spend my time.
Old Apr 1, 2026 | 06:21 PM
  #5619
Philip_A's Avatar
Uuugh, the cam covers are leaking AGAIN.
I can't get them not to leak, this sucks. I guess they have a warp to them. Front lower edge leaks on both. Sealant did nothing.
Sucks because the car stinks of burning oil all the time. Anyone have any hints?
Phil
Old Apr 3, 2026 | 01:48 PM
  #5620
Philip_A's Avatar
Addressed the valve covers today.
Well, that was leaking. Looks like the corner never sat down right. The old sealant had come up from the surface, which is weird because it is what was specified by Jaguar.
Cleaned all the sealing surfaces up.
A generous helping of Permatex Oil Resistant RTV.
Did that to both sides. That can sit and cure now.
Phil
