What is this part called (photo inside)
Old May 8, 2012 | 06:58 PM
Newby's Avatar
Default What is this part called (photo inside)
HI,
Please see picture below. This photo is taken looking in the passenger front side wheel well. When you're done shaking your head after looking at the added screws, could you please tell me what is this part called? The part in question is the squarish plastic piece (approx 7" or so square with a rectangular 3" x 2" or so hole in it) that receives the squarish pipe/tube that directs air flow from the front of the car to the brake area. I need one for the driver's side (lost it on the freeway)
I was bad.... parked too far in on a parking spot and managed to hook part of the front underside/air dam area/chin area and knocked the plastic stuff loose. I pulled out the loose air ducting (passengers side) and put it in the trunk. While on the freeway I saw the part in question go flying off from the driver's side.
If I know what it is called, I could more easily find a replacement.
Old May 8, 2012 | 07:23 PM
OldMike's Avatar
Ia it the mounting bracket (?) for the brake cooling duct?
Jaguar XJ8 XJR X308 - FRONT WHEEL BRAKE DUCT MOUNT / COOLING VENT **FREE P+P** | eBay
Old May 8, 2012 | 08:27 PM
Newby's Avatar
WOW! Thank you! I just bought that part.
Here is a pic of my 2002 XJ8, also in Blue Zircon
Attached Thumbnails What is this part called (photo inside)-pretty-kitty.jpg
Old May 8, 2012 | 08:49 PM
OldMike's Avatar
Cool! Hope the part does the trick for you!
Beautiful car you have there! LOL
Old May 15, 2012 | 12:18 AM
JKo's Avatar
JKo
Just noticed that my XJR is missing the same part from the right side. The brake duct itself was held in place pretty much by gravity.
I found one bracket from eBay, but postage to Finland is quoted $127...
brake cooling duct bracket / hnc4469af | eBay
Luckily they put the Jaguar part number (hnc4469af) on their listing, which hopefully makes the part a bit easier to find.
philwarner
Oct 4, 2024 01:37 PM
tberg
Sep 7, 2015 07:32 AM
XFR_Gold
Sep 2, 2015 12:24 PM
innzane
Sep 2, 2015 10:08 AM
TC Johnson
Sep 2, 2015 09:30 AM
