What is this part called (photo inside)
Old Jun 9, 2012 | 10:44 PM
Newby's Avatar
Default What is this part called (photo inside)
I just figured it out, the part I need is the sunroof control module.
My sunroof button only makes the motor run one way. When I hooked up a new motor, same result.
When I took this part out of my other 2002 XJ8, the motor works opening and closing directions. I took it apart and sprayed contact cleaner on the button, but it still does not work...
There is one "sunroof control module" on ebay for $68 that fits the 2002 XJ, does anyone know where I may find a cheaper one??
Thank you in advance for your help
Attached Thumbnails What is this part called (photo inside)-2012-06-09-19.34.25.jpg
Old Jun 10, 2012 | 07:40 AM
motorcarman's Avatar
It's called an 'overhead console'.
The part can be found in salvage yards but the trim would have to match unless you are just using it for the GDO parts.
bob gauff
Old Jun 11, 2012 | 09:47 AM
Newby's Avatar
Yes, I am only needing the module which houses the control for the sunroof operation. Anyone know where I can get one cheap?
Old Jun 11, 2012 | 11:16 AM
XJR-0220's Avatar
junkyard would be an easy cheap place to get one
philwarner
Oct 4, 2024 01:37 PM
tberg
Sep 7, 2015 07:32 AM
XFR_Gold
Sep 2, 2015 12:24 PM
innzane
Sep 2, 2015 10:08 AM
TC Johnson
Sep 2, 2015 09:30 AM
