Wheel Shake
Old Jul 27, 2007 | 10:20 AM
Default RE: Wheel Shake
Hey there rdc..........If you have a wheel shake as you call it, the chances are that its the wheel balancing that hasn't been done properly and nothing to do with alignment.
If you've bought them fairly recently, take it back to the garage and explain and ask them to rebalance them for you. They should do this for free.
Jim
Old Jul 27, 2007 | 10:36 AM
93xj6's Avatar
Dang JPS drivin a lil fast are you
Old Jul 27, 2007 | 12:15 PM
FL XJR's Avatar
ORIGINAL: 93xj6
[sm=smiley22.gif]
My car doesnt engage 4th gear 'til 90 (and I still have one gear left)!
Old Jul 27, 2007 | 01:46 PM
bigdreams05's Avatar
DAMN XJR...as for Jim, 93XJ, and Jeehova...you guys really need to see the post dates!
Old Jul 27, 2007 | 07:25 PM
ORIGINAL: jps
Just bought a 2000 xj8 3.2 and noticed a slight shake in the steering column at 70mph which smooths out at 90mph. I'll check brake heat and brake calipers.
Errr Biggie ( Albert! ) you might want to see the post dates....lol
Jps posted on 26/07/07......DUHH
Jim
Old Jul 28, 2007 | 09:33 AM
jag_genius's Avatar
i d start with a wheel balance
http://stores.ebay.com/JAG-GENIUS
Old Oct 9, 2007 | 08:49 PM
SpartanX's Avatar
Ditt on the wheel balance. That solved my problem.
Old Oct 31, 2007 | 09:37 AM
I would do more than just rotate the tires though. The reason that it is driving better is because of the lack of wheel play in the rear because it's a fixed wheel, not movable by a rack and pinion like the front. However, unbalanced wheels cause unnecessary bushing wear on the rear bushings and suspension parts. Believe me, after a while it makes a difference. I would balance the wheels if I were you.
H20boy
Dec 24, 2024 03:23 PM
yoiyoi
Dec 19, 2023 12:51 AM
alfred
E type ( XK-E )
Sep 14, 2015 08:38 AM
Safari
Sep 7, 2015 10:33 AM
JagLove86
Sep 6, 2015 10:36 PM
